Problems accelerating - Mustang Evolution
Old 09-21-2013, 10:11 PM   #1
Minus2380's Avatar
Got a problem during acceleration...it feels like a little 6 banger. I just changed the balancer and got the timing up to thirteen degrees. Drove it and has little power. Any suggestions?
Minus2380 is offline   Reply With Quote
Old 09-22-2013, 12:16 AM   #2
jduckz5.0's Avatar
Need more info...how's tune up on it,fuel pressure,maf,etc...could be just battery or alt going bad....
jduckz5.0 is offline   Reply With Quote
Old 09-22-2013, 08:24 AM   #3
Minus2380's Avatar
When I give it gas from the start it just doesn't have any gid-up till bout 3000 rpm then it will pull a little harder. Just doesn't feel like a V8 should when u give it gas
Old 09-22-2013, 08:32 AM   #4
jduckz5.0's Avatar
Check timing chain,catalytic converter,fuel pressure....wait stick or auto????
Old 09-22-2013, 08:34 AM   #5
Minus2380's Avatar
Stick and I have no cats
Old 09-22-2013, 08:50 AM   #6
jduckz5.0's Avatar
I see that's y u changed harm. Balancer??? I would Check if your is charging under power...and check fuel pressure...this might be a long shot but if its just holding back 3k check your emergency brake cables and rear brakes...
---------- Post added at 10:50 AM ---------- Previous post was at 10:50 AM ----------
Alternator
Old 09-22-2013, 08:54 AM   #7
Minus2380's Avatar
I just replaced the harmonic balancer. Dumb thing spun on me. Then i bumped the timing to 15. Started at 10 then went to up to 15.
Old 09-22-2013, 09:02 AM   #8
jduckz5.0's Avatar
Did it ping at 15???
Old 09-22-2013, 09:07 AM   #9
Minus2380's Avatar
Not at all. We had it up to 18 with no ping but I figured it was not safe at 18 so we brought it down to 15
Old 09-22-2013, 09:38 AM   #10
jduckz5.0's Avatar
18 and it didn't ping??? Seems high are you sure your marks are right on balancer??? I ask because if my timing is too low the car doesn't run good upto 3k just like yours...too high and it pings and wont run good up top...I say take it bump it up and take for a ride...
Old 09-22-2013, 09:43 AM   #11
Minus2380's Avatar
It should be right it's only 2 days old. Yea I'll take it up to 20 and try it
Old 09-22-2013, 09:58 AM   #12
jduckz5.0's Avatar
Don't forget to run 93 octane or 91...
Old 09-22-2013, 10:23 AM   #13
Minus2380's Avatar
Ok right on. I'll let u know how it goes
Old 09-22-2013, 04:21 PM   #14
Minus2380's Avatar
Still a not the same. Next weekend I'm going to get a fuel pressure gauge and check it
Old 09-22-2013, 04:37 PM   #15
jduckz5.0's Avatar
What did u do???
Old 09-22-2013, 04:53 PM   #16
Minus2380's Avatar
Messed with the timing a little. Cleaned my maf and air filter.
Old 09-22-2013, 05:13 PM   #17
jduckz5.0's Avatar
Post wat pressure was...
---------- Post added at 07:13 PM ---------- Previous post was at 07:12 PM ----------
How's your plugs look???
Old 09-22-2013, 05:49 PM   #18
Minus2380's Avatar
Yea plugs are good and the resistance on the wires are good.
12:13 AM
