immediate help needed - Mustang Evolution
Old 09-23-2013, 07:11 AM   #1
captain78's Avatar
Ok i need opinions. Ok my fox is stalling. It idles perfect but runs strong but when driving and you go to stop take foot off gas it acts like i just turned key off. Everything is new except distributer and coil. Help im lost
captain78 is offline   Reply With Quote
Old 09-23-2013, 09:29 AM   #2
351stroker's Avatar
idle air motor new?
351stroker is offline   Reply With Quote
Old 09-23-2013, 09:50 AM   #3
captain78's Avatar
Yep
Old 09-23-2013, 10:18 AM   #4
Reset the idle and check the set screw. Also check your TPS voltage.
Old 09-23-2013, 12:47 PM   #5
captain78's Avatar
Did and done it idles like a champ just not once you get on throttle Im about to order new MSD idnition system
Old 09-23-2013, 12:59 PM   #6
351stroker's Avatar
are you mass air or speed density. I know my speed density gives me trouble.
Old 09-23-2013, 01:15 PM   #7
captain78's Avatar
Mass air
Old 09-23-2013, 10:16 PM   #8
351stroker's Avatar
How big of fuel pump? Adjustable regulator?coil might be a good bet as well. What kind of coil?
Old 09-24-2013, 06:30 AM   #9
captain78's Avatar
Bbk 255 fuel pump and adjustable regulator set at 40lbs
Old 09-24-2013, 06:35 AM   #10
captain78's Avatar
And coil is cheap and old autozone coil Thats prolly 10+ years old
Old 09-24-2013, 09:08 AM   #11
Well start with the simple stuff first although don't just throw parts at it... been there, done that. Coil is not expensive and at 10 years could stand to be replaced. Is the distributor orignal?
Old 09-24-2013, 09:26 AM   #12
captain78's Avatar
The confusing part is is that it only does it when car is in motion sitting still you wouldnt think anything is wrong with it. Go to take it around block or even just doing a burn out hit clutch come of gas and it dies like you turned the key off
Old 09-24-2013, 09:33 AM   #13
What is your TPS voltage at?
Old 09-24-2013, 09:40 AM   #14
captain78's Avatar
.99
Old 09-24-2013, 10:41 AM   #15
351stroker's Avatar
For $50 a coil isn't a bad place to start. But kinda sounds like a vacuum leak or IAM isn't picking up fast enough.
Old 09-24-2013, 10:52 AM   #16
captain78's Avatar
Def not a vacuum leak got those taken care of just hung up phone with frpp tech and he said sounds lile a bad ground because it runs strong and idles great unless moving and warm so being i just ordered whole new ignition set up. Im gonna go back and look at all my grounds too
Old 09-24-2013, 12:01 PM   #17
That's always the first thing you should check. The main grounding strap goes from the left motor mount to the frame and ALWAYS gets crudded up and corroded. Even if it looks ok I'd replace it with a 4 gauge battery cable and then add another one to the passenger's side.
Old 09-24-2013, 12:11 PM   #18
captain78's Avatar
Well i have brand new 0gauge ground plus little ground to back of eng
---------- Post added at 01:11 PM ---------- Previous post was at 01:09 PM ----------
But dosnt mean it couldnt have come loose
Old 09-25-2013, 09:16 AM   #19
351stroker's Avatar
Hey, maybe that's what's with mine.... Even alt reads a little low bit when I put meter in it says charging is good. But damn thing seems to always want to stall out when I put clutch in. One more thing to check when I get it into the shop.
01:35 AM
