Converting to mass air - Mustang Evolution
Old 09-24-2013, 05:31 PM   #1
93turbocobra's Avatar
I am needing help I am trying to convert my 87 speed density car to mass air I have the harness, the computer , and the mass air meter. I have it all put in and my car won't start I have no power to my fuel pump or to my injectors. My ignition coil does not have power with the key off but does with the key on and it got really hot. Does any one have any pointers or can help me out with this.
93turbocobra is offline   Reply With Quote
Old 09-24-2013, 09:12 PM   #2
jduckz5.0's Avatar
Go thru everything you wired up and double check they are correct...sounds like you got two hot wires connected or touching...
jduckz5.0 is offline   Reply With Quote
Old 09-25-2013, 10:38 AM   #3
Ok thanks I am wondering why I do not have power to my pump or injectors
Old 09-25-2013, 01:57 PM   #4
jduckz5.0's Avatar
Get a Haynes manual...to help you figure what each wire you cut might have to do with fuel...if no power to pump that's probably the wire that is touching or not grounded so its going to coil...
09:58 PM
