shakes and smoke - Mustang Evolution
Old 09-24-2013, 10:58 PM   #1
90fox's Avatar
shakes and smoke
Hopefully don't go out in blaze of glory way home. Decided to drive stang to farther job tonight about 30 miles partial highway, big traffic at a part. Once got on up to speed 70+-80 felt like shaking..never done few other times been on freeway. Then parked and smoke came out bezel again. I knew where it was going to be coming from because before got clutch and trans replaced it did this. Trans fluid drips down onto x/h pipe whichever I have. Has not done this until today since clutch/trans replacement. Ffgvhvdjb
90fox is offline   Reply With Quote
Old 09-24-2013, 11:53 PM   #2
90fox's Avatar
Made home didn't seem to have issue. Babied it no hard acceleration, kept at 60-65 most way on freeway. Few times for very short while brought to 70 didn't seem to shake. Tried not to downshift other than from 5th-4th and neutral. One turn need to go down to 3rd. Pulled in driveway..didn't see smoke. Tried to shine backlight from phone down under there..didn't see any fluid bubbles or dripping. When it does/did, drips from grommet area where front of driveshaft meets back of trans.
Old 09-25-2013, 08:36 AM   #3
bigmac3's Avatar
Man, I hate reading posts put in from phones.
Shaking at isolated speeds usually indicates tire imbalance. If you feel it in the steering wheel, it's the fronts and if you feel it in your seat, it's the rears. Driveshaft/u-joint problems usually produce a vibration or loud hum. Not sure of which bezel you are referring to.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 09-25-2013, 10:38 AM   #4
90fox's Avatar
Sorry...ya I tend to write quick and fragmented sentences. Tire could be, I did just recently put a used tire/rim on rear. The bezel I speak of is my shifter bezel.
---------- Post added at 09:38 AM ---------- Previous post was at 09:37 AM ----------
Rear passenger tire
Old 09-25-2013, 10:41 AM   #5
bigmac3's Avatar
Rear passenger tire
Still can't help you with the bezel thing but I think the tire may be your culprit. Good luck.
Frank
Old 09-25-2013, 10:42 AM   #6
90fox's Avatar
Makes sense. 5spd..leather boot/plastic ring
Old 09-25-2013, 10:47 AM   #7
90fox's Avatar
Trans fluid drips down onto exhaust, obviously hot so smoke comes straight up through shifter. Drips from where driveshaft meets transmission. Did this before replaced clutch kit and a used transmission. Never again until yesterday.
04:21 PM
