1995 fog lights (HELP!!) - Mustang Evolution
Old 09-28-2013, 03:30 PM   #1
badsheep5.0's Avatar
ok well my fog lights stopped working today the light on the switch to turn them on still glows but the lights do not turn on and yes I have headlights on and no they are not on high beam. I was reading that this is because one of the bulbs is burnt out or it could be some wiring is toast they were working last night. so please give me some advice if you can
badsheep5.0 is offline   Reply With Quote
Old 09-28-2013, 03:47 PM   #2
Doe_Rae_mi's Avatar
Check to your wiring and make sure everything fine. If it is it's Ur bulbs
Old 09-28-2013, 03:53 PM   #3
I will do that when I get off work. I am debating if I should pick up bulbs anyway apart of me thanks yes because even if that's not it idk when they were last replaced anyway
Old 09-28-2013, 04:11 PM   #4
jduckz5.0's Avatar
Check your fuse...
jduckz5.0 is offline   Reply With Quote
Old 09-28-2013, 04:47 PM   #5
[QUOTE="jduckz5.0;1810462"]Check your fuse...[/QUOTE
That would prob be the quicks and most easy I can't belive I did not thank of this step
Old 09-28-2013, 05:12 PM   #6
jduckz5.0's Avatar
Lol hopefully its that simple...
Old 09-28-2013, 05:42 PM   #7
yeah I hope so also I already looked at some aftermarket ones if there toast ill go with the tinted ones from am
Old 09-28-2013, 05:52 PM   #8
jduckz5.0's Avatar
Are your lenses cracked??? Or would you rather just buy from am with the bulbs in it???
Old 09-28-2013, 05:54 PM   #9
I was reading I might have to get a whole new unit I hope not I would rather get these working then put tint on them
Old 09-28-2013, 06:27 PM   #10
jduckz5.0's Avatar
You have bulbs that go in...unless yours are cracked...but check fuses first...then check bulbs...its not common for both to burn out at same time...
Old 09-28-2013, 06:28 PM   #11
I know that's why if its not fuses it a bigger issue
Old 09-28-2013, 07:24 PM   #12
Check your fuses, check your bulbs, check the wiring and take a multimeter to the plug and see if you are getting power to it. Could be a bad switch too... luckily this is something that is not too hard to troubleshoot.
Old 09-29-2013, 11:48 AM   #13
94CobraUSMC's Avatar
Make sure to check the connector under the center console
94CobraUSMC is offline   Reply With Quote
Old 09-29-2013, 12:43 PM   #14
Well the little Orange light is still turning on
Old 09-29-2013, 12:45 PM   #15
idk if that affects that I just know that's where the connector is I had to get in there and switch some wire so my fog would come on without my headlights. It's a black connector with a red plastic tab.
Old 09-29-2013, 12:47 PM   #16
I'll look in to it when I can get it in a garage it's raining bad in the northwest not that that is really a surprise
Old 09-29-2013, 12:49 PM   #17
ok just open your center console take out the line 6 screws I think and it should be ride there. Yea I feel you on the rain it's an everyday thing here in Japan
Old 09-29-2013, 12:55 PM   #18
jduckz5.0's Avatar
If the light is on then its still connected...I would open console until you check everything else...
Old 09-29-2013, 01:11 PM   #19
+1
Old 09-30-2013, 06:06 AM   #20
mystang50's Avatar
check the bulbs, mine did same because the lenze was cracked and water got in and fried the bulbs.
Old 09-30-2013, 06:46 AM   #21
I plan on it rain just needs to let up we're getting the end of the stuff going on in Japan
Old 09-30-2013, 06:50 AM   #22
ha I'll try to slow it down for ya
Old 09-30-2013, 05:07 PM   #23
Well guys storm let up went out checked fuse if was find and it's been dry for about a hour or took so snapped a photo of my fogs looks to me like there was a crack or some thing
ID:	130940   Click image for larger version
Old 09-30-2013, 08:50 PM   #24
3stangs's Avatar
Condensation in the housing. The bulb probably fried. If one light is out they don't come on
3stangs is offline   Reply With Quote
Old 10-04-2013, 10:31 PM   #25
Yeah debating on ordering New houseing if I do I will be ordering smoked ones
Old 10-04-2013, 10:32 PM   #26
Just buy an OEM Cobra bumper and do the Envoy fogs. Will give you an excuse to upgrade lol.
Old 10-04-2013, 11:23 PM   #27
Think I would rather spend 75 on smoked fogs and save for a 3 inch cowl
Old 10-04-2013, 11:35 PM   #28
It's not me, it's you.
primer2tone's Avatar
Excellent idea!
Old 10-05-2013, 11:38 AM   #29
Originally Posted by primer2tone View Post
Excellent idea!
Don't get me wrong the cobra bumper is sexy and one day ill prob add it but I thank 3 inch cowl is much more sexy
Old 10-05-2013, 04:11 PM   #30
Cowl AND Cobra bumper AND Envoy fogs.
Just sayin...
:p
Old 10-05-2013, 04:13 PM   #31
Just sayin...
:p
+ 1 love it
Old 10-05-2013, 04:17 PM   #32
Just sayin...
:p
looks great
Old 10-09-2013, 08:53 PM   #33
Well guys replaced the lights and saw that the passenger side fog has water sitting in the bottom so I believe that is the sign to pick up son new ones
Old 10-10-2013, 06:01 AM   #34
mystang50's Avatar
I took mine off, dried them out, sealed them up and put them back on...but I'm cheap like that lol
Old 10-10-2013, 07:10 AM   #35
You can get the OEM ones for super cheap
Genuine Ford Parts - OEM Ford Parts - BlueSpringsFordParts.com
01LaserCobra is offline   Reply With Quote
04:19 AM
