Some help please - Mustang Evolution
Old 10-03-2013, 07:17 PM   #1
Yzfoxracer's Avatar
Some help please
Okay so I know this says 79 through 95 but I have a 71 Mach 1 with a 302 carbureted engine in it and I need some help
Okay so first off I have a Elderbrock (or however you spell it ) carburetor 700 CFM's and I just replace the gasket between the intake and the carburetor cause it was bad. Now it's running like ***** when you put it in gear when it's in park or neutral it runs fine but when he put it in reverse or drive it starts running like ***** and stalls out also sometimes it's really hard this start after it's been running (after stalls out)because I think the choke is staying open and it's doing something I don't know but it's hard to start so I need some help with this anybody have an idea about anything
ID:	131332   Click image for larger version
ID:	131334   Click image for larger version
Yzfoxracer is offline   Reply With Quote
Old 10-03-2013, 08:29 PM   #2
jduckz5.0's Avatar
Sounds like the float is sticking...when you changiged the gasket did you flip over or move carb alil too much???
---------- Post added at 10:29 PM ---------- Previous post was at 10:28 PM ----------
Recheck your vacuum lines...
jduckz5.0 is offline   Reply With Quote
Old 10-03-2013, 08:32 PM   #3
Yzfoxracer's Avatar
Originally Posted by jduckz5.0 View Post
Sounds like the float is sticking...when you changiged the gasket did you flip over or move carb alil too much??? ---------- Post added at 10:29 PM ---------- Previous post was at 10:28 PM ---------- Recheck your vacuum lines...
no It was doing this even before I replaced the gasket
Old 10-03-2013, 09:53 PM   #4
jduckz5.0's Avatar
Is it electric or manual choke???
Old 10-03-2013, 09:59 PM   #5
jduckz5.0's Avatar
I'm assuming its an auto...do you know how to adjust your idle to match stall converter??? Sounds like when you put it in gear its flooding out...
Old 10-04-2013, 04:27 AM   #6
Yzfoxracer's Avatar
it's a electric choke and it's a auto trans and it's running to lean
Old 10-04-2013, 07:47 AM   #7
jduckz5.0's Avatar
Have you checked the vacuum on distributor???
Old 10-04-2013, 08:58 AM   #8
Yzfoxracer's Avatar
I think I got it I think it was the intake it was a lil loose and not torked to specs
Old 10-04-2013, 09:13 AM   #9
jduckz5.0's Avatar
Nice find...
Old 10-04-2013, 10:14 AM   #10
Yzfoxracer's Avatar
Nice find...
thanks tho
Old 10-10-2013, 04:51 PM   #11
Yzfoxracer's Avatar
Nice find...
yeah that wasn't it , I put a new carb on it and it's still running like crap also I used a timing gun and that fine I'm going to check the disturber tomorrow
Old 10-14-2013, 10:08 AM   #12
jduckz5.0's Avatar
Did you figure it out???
Old 10-14-2013, 04:41 PM   #13
5.oh's Avatar
I would say it's the timing. I adjusted mine to 14 degrees BTC and it started running like **** when I'd put it in gear but it'd run fine in neutral or park. So I adjusted the throttle plate when in gear with the e brake on, just so it wouldn't choke out. It runs perfectly fine now.
5.oh is offline   Reply With Quote
03:52 PM
