1988 Mustang suspension - Mustang Evolution
Old 10-05-2013, 09:47 AM   #1
1987mustanglx50's Avatar
I want to swap the suspension from my 1988 Mustang Lx 5.0 to a 1994 Mustang gt 5.0 suspension does anybody know is their any modification that need to be done or will it bolt on to it? Any help will be greatly appreciated and thank you in advance
1987mustanglx50 is offline   Reply With Quote
Old 10-05-2013, 12:15 PM   #2
realspeeddan's Avatar
Define what parts of the suspension do you want to swap?
Lower upper and lower rear control arms will swap right in.
The springs will swap right in but the ride height may be slightly different.
The shocks and struts will fit but are shorter, which is fine on a lowered car but may cause problems with stock springs.
The caster camber plates (strut mounts), and front swaybar are different. Rear swaybar will bolt right in.
realspeeddan is offline   Reply With Quote
Old 10-05-2013, 01:50 PM   #3
Am more of looking to swap the front and rear disc brake system but I would like to swap as much as I can also
04:32 PM
