Corvette engine swap - Mustang Evolution
Old 10-07-2013, 04:05 PM   #1
86foureyes's Avatar
Hello everyone I know I might get some hate on this but I'm trying to research an 80's model 350 h/o corvette engine swap into my 1986 gt which you all know is fuel injection. I wanna know if I should change the gt to carb or get an intake with a throttle body for the corvette engine. Also where I can find motor mounts and a k-member thanks
86foureyes is offline   Reply With Quote
Old 10-07-2013, 04:25 PM   #2
If you are going to swap a GM engine into it you should at least do an LS motor, so much more potential. Sad to say, but they even make kits for Mustangs to swap in LS motors.
Old 10-07-2013, 05:02 PM   #3
Why would you swap to such a sad motor?
Old 10-07-2013, 05:36 PM   #4
86foureyes's Avatar
The reason I want to swap is because I have an opportunity to buy a worked up motor and trans for $500 it has been siting in the garage since the 80's and the guy paid $500 for it when he was 20 and was going to put it in his Chevelle but sold the car
Old 10-07-2013, 05:49 PM   #5
Specifically which motor? And what has been done to it? The Corvette's 80s engines didn't make all that much power.
Old 10-07-2013, 06:46 PM   #6
86foureyes's Avatar
All I know so far is that it was built for a drag car and was all hopped up and suppose to be a nasty motor. There's a story that comes along with the motor. But it's a 350 h/O corvette engine. I'm going to take the serial numbers off it this week an check it out to find out the exact year etc. and he said if I'm interested I can pull the heads and pan to see what's done to it. It also comes with a standard transmission. Matching numbers either 4 or 5 speed
Old 10-07-2013, 07:44 PM   #7
ColeJohnson's Avatar
The early 80s cross fire fuel injected corvettes made less than 190rwhp. I wouldn't do it...
Unless all that work was essentially changing everything about the engine. The early 80s corvettes looked amazing but were straight dogs. I could probably beat one off the line on my bicycle.
2016 Comp Orange GT (current)
Old 10-07-2013, 08:25 PM   #8
Been sitting in the garage since the 80s? You think he rotated it and kept it properly lubricated just sitting there in the garage for 30 years? Guarantee it needs another full teardown and rebuild. You could probably pull a good 5.3L out of a JY for not much more money and run with that.
Old 10-07-2013, 08:33 PM   #9
1lowGT's Avatar
+1
Old 10-07-2013, 09:15 PM   #10
Roguestang's Avatar
Yeah if its been sitting that long, its gonna need another rebuild....... not worth it IMO.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 10-07-2013, 10:21 PM   #11
Sybesma07's Avatar
Look into it and find out what's all been done to it. If it's a stock motor then yeah like everyone else said. Not worth it. If it does have after market parts. Buy it for sure, Shoot buy it anyways but my suggestion is to find another car to put it in. It will be a pain to put it in a mustang. Find a 80's-90's camaro. Plus no matter what you'll have to rebuild it.
Sybesma07 is offline   Reply With Quote
Old 10-08-2013, 06:27 AM   #12
86foxbody's Avatar
When i switched my 86 gt to carb i spent about 1400 just to make it run
86foxbody is offline   Reply With Quote
Old 10-08-2013, 07:16 AM   #13
Old 10-08-2013, 10:21 AM   #14
Sybesma07's Avatar
Lol I like. I sell a lot of ford parts and my friend sells chevy parts. He get all kinds of characters buying chevy parts. I would just rather see him put it in a chevy then a 86 mustang GT or any ford at that.
Old 10-09-2013, 04:52 AM   #15
86foureyes's Avatar
I understand it will need a rebuild no mater what I've already set that into mind the only reason I wanna do it is cause of all the upgrades it supposedly has. I haven't come to a full conclusion on putting it into the fox I might put it into my 89 c1500 2wd and make it a sleeper
10:41 AM
