Shorty r long tube ??? - Mustang Evolution
Old 10-08-2013, 06:23 AM   #1
Frenchstang's Avatar
Hen i showed some pics last week scott said it was stock headers tks to him he was right ! But all the rest is bbk ! My question is is it worth it to pu long tube and buy everything again (hp wise) or just buy shorties and plug the rest
Which will work great anyway have a good day !
ID:	131847   Click image for larger version
Frenchstang is offline   Reply With Quote
Old 10-08-2013, 11:52 AM   #2
Longtubes are better if you can afford them but the FMS shorties are not too much money, fully stainless and you can get them in ceramic for a little more and they are OEM. You'll spend at least double or triple to get the longtubes in. I'd honestly get the shorties and call it a day.
From the flange on the flow tube and the color of the flow tube it looks like that's a stock catback too or at least you've got a stock catback with aftermarket mufflers. I'd get shorties and a real catback before buying longtubes and a new midpipe.
Old 10-08-2013, 08:24 PM   #3
Tks good advice ! I ll keep u posted with pics !
Old 10-09-2013, 08:15 AM   #4
Also if you get shorties do yourself a favor and get the Ford Racing Ceramic coated ones. DO NOT cheap out and get a $150 set of Flowtechs or some crap. They'll turn white after a week and start rusting within 6 months. Even the BBKs are not the greatest. I had a set of FRPP Ceramic shorties on my 95 from 2003 to 2009 and they looked nearly brand new when I pulled them.
Old 10-09-2013, 09:39 AM   #5
I ll check it out for sure . I want to keep that car for a long time , so i wont be cheap ! But my mid pipe is bbk does it matter ? Any other brand will fit ?
Old 10-09-2013, 10:00 AM   #6
BBK pipe will fit fine.
Old 10-09-2013, 11:24 AM   #7
Ohdang1990's Avatar
Are your heads and cam stock? If not what are they?
Ohdang1990 is offline   Reply With Quote
Old 10-09-2013, 01:09 PM   #8
That would only matter if he was running some huge heads that needed 1 and 3/4 primaries or even 1 and 7/8 which he is not IIRC. Not relevant.
Old 10-09-2013, 01:35 PM   #9
Ohdang1990's Avatar
Actually, I have GT40x heads which happen to be intake biased so they need as much help on the exhaust side as they can get (i.e. longtubes). Which, may I remind you, are not big heads. So yes, it does happen to be relevant.
Old 10-09-2013, 05:15 PM   #10
The egine is bonestock for now i will buy the 1 5/8 shorties and a good cat back too ! Tks for advices !
I do have a question ! I will make it clear this time ( sorry for the last time my english still need a little bit of work !!
1: everytime i looked for throttle body ,it most of the time come with a spacer , do i need that to make it fit good with throttle cable or is just to give me more hp ??? With or without spacer is it direct fit ? Tks guys ur advise help me to go on the right direction !!!
Old 10-09-2013, 09:44 PM   #11
All heads will benefit from Longtubes over shorties and I did mention to him that longtubes are the best but yes he will probably pay triple of even the FRPP shorties to get them in which is why I suggest the shorties. And I honestly thought you were going to mention primary sizes.
Old 10-09-2013, 10:02 PM   #12
Ohdang1990's Avatar
Of course all heads will benefit from longtubes. If you have the money and don't mind putting up a fight with the instal get LTs. If not, no big deal. With stock heads you won't be sacrificing enough power for you to worry about. Plus shorties are an extremely easy instal.
Old 10-09-2013, 10:14 PM   #13
Ohdang1990's Avatar
Sorry about your other question fella. I got caught up in the first one. You don't have to put the spacer on if you really don't want to but what the spacer does is add extra distance for the air to travel which creates more turbulence in the flow which creates a more complete combustion. That's what the "experts" will tell you anyways. I personally can't say that I believe that 100%. However, I have one on mine because it came with it. It can't hurt to have it on there just in case it does what they say it does!
Old 10-10-2013, 09:17 AM   #14
Tks ! But if i put the spacer on will i need new throttle cable aswell or it will be direct fit too ! Tks for helping me out guys !
Old 10-10-2013, 10:26 AM   #15
Ohdang1990's Avatar
The throttle cable you have will fit back up just fine
Old 10-10-2013, 04:57 PM   #16
Tks !!! I ll keep u posted !
09:36 AM
