P/A 3g alternator upgrade - Mustang Evolution
Old 10-09-2013, 11:37 PM   #1
Just completed alternator upgrade in my 88gt, now I have an annoying chirp coming from either the alternator pulley or the tension pulley. Belt size is 90.8inches for A/C, power steering, and smog delete pulley. I've replaced the power steering pump as well. Any idea what would cause this , the tension pulley, alternator pulley, smog delete pulley are all new as is the serpentine belt. The " chirp" goes away once the engine warms up but that still takes about 10 minutes before the chirp stops. Any help or suggestions would be appreciated thanks!
Jriver34 is offline   Reply With Quote
Old 10-10-2013, 01:26 AM   #2
Jzelm10's Avatar
Mine does this also.. it's so annoying! If you spray the belt with lube it stops but its back like 2 days later
Jzelm10 is offline   Reply With Quote
Old 10-10-2013, 09:09 AM   #3
jduckz5.0's Avatar
Probably just got some grease or dirt on belt...exchange it and go from there...
jduckz5.0 is offline   Reply With Quote
Old 10-10-2013, 11:56 PM   #4
Thanks I think cleaning the grooved surface of the pulleys really made a difference I noticed the felt from the belt was rubbing off and collecting in the grooved areas hopefully that will correct that chirp thanks.
Old 10-11-2013, 06:31 AM   #5
jduckz5.0's Avatar
Good luck..I used to use brake parts cleaner on the pulleys...and I used dawn to wash belt and let it dry before I put it back on...I spend a lot of money at AutoZone so they exchange or replace it for free..haha
08:18 AM
