Replace fuel filter - Mustang Evolution
Old 10-11-2013, 06:19 PM   #1
Liebert91stang's Avatar
Replace fuel filter
Replaced my fuel filter today and it took care of the hard start.old one still said ford so it probably original.seems to have better throttle response and possible hp.guess the injectors are getting proper fuel now.i google it and says to change them annually,does this sound correct to anyone?
Liebert91stang is offline   Reply With Quote
Old 10-11-2013, 06:54 PM   #2
jduckz5.0's Avatar
I do because of the ****ty gas these days and my tank is original so could had some debris in it from over the years...
jduckz5.0 is offline   Reply With Quote
Old 10-11-2013, 07:49 PM   #3
I will definitely keep that in mind.figured about every 5 years.guess you never know what the storage tanks gas stations use have in them
Old 10-11-2013, 09:26 PM   #4
You should change them out every year yes. Also your injectors themselves are likely clogged up somewhat as well. You should have seen the originals I pulled out of my 95 and that was back in 2007 lol.
Old 10-12-2013, 06:43 AM   #5
Can you clean the injectors without messing them up?
Old 10-12-2013, 12:36 PM   #6
Fuel filter every 15k to 20k miles.
Id send the injectors out to be cleaned and tested. There is a tiny fuel filter inside of them that should be replaced that everyone overlooks.
I recently used mrinjector.com and was very pleased with the results.
Old 10-12-2013, 01:01 PM   #7
I didn't know that.want to get 24lb later down the road after heads and intake but not sure how long that will be.may try find someone to clean them for now
Old 10-12-2013, 02:10 PM   #8
jduckz5.0's Avatar
Run some fuel injector cleaner in your tank for the next few fill ups....
Old 10-12-2013, 03:34 PM   #9
I just ran some about 2weeks ago but that was before I changed filter.too much won't burn them up?
Old 10-12-2013, 03:42 PM   #10
Nope.
It will just "burn up" all of the money in you wallet...
Old 10-12-2013, 04:00 PM   #11
jduckz5.0's Avatar
+1lol...
Old 10-12-2013, 04:04 PM   #12
True that.i spend it like it's going out of style
Old 10-12-2013, 04:35 PM   #13
My injectors were falling apart. There was no cleaning them. I got some remanufactured 24s for under $200 on eBay and the car ran way better.
Old 10-12-2013, 04:41 PM   #14
Normally, an original set is your best bet. Some of the ebay injectors can be badly mismatched as far as spray patterns and flow goes.
Old 10-12-2013, 05:04 PM   #15
Mine were from a shop/store on ebay that reconditions and flow matches them. I had the sheet for them and everything. Not my first rodeo lol.
Old 10-12-2013, 05:15 PM   #16
McNassty's Avatar
http://m.summitracing.com/parts/ctr-25-910http://m.summitracing.com/search/yea...esults=display
McNassty is offline   Reply With Quote
Old 10-12-2013, 05:20 PM   #17
Lmao.
I'm gonna buy two... One to install on the car and one to keep in the trunk as a spare...
Old 10-12-2013, 07:12 PM   #18
I always thought summit was high but that is a good deal
Old 10-12-2013, 07:20 PM   #19
Lol.
Were we looking at the same thing?
I saw a $100+ fuel filter...
Old 10-12-2013, 08:21 PM   #20
The link is for fuel injectors when I pull it up.if that's a filter i would hope nobody would pay that lol
Old 10-12-2013, 08:26 PM   #21
Haha.
It wouldn't work when I tried it a while ago.
SMH. Crazy interwebnet thingamajobby...
Old 10-13-2013, 06:40 AM   #22
Haha you said it best
Old 10-13-2013, 10:03 AM   #23
McNassty's Avatar
I have that filter, it's a replaceable element filter, the last filter you have to buy. Just replace the elements
07:27 PM
