Help - Mustang Evolution
Old 10-14-2013, 09:24 PM   #1
Yzfoxracer's Avatar
What can cause my 302 to run like crap when still but good when driving it I've already checked the following and there fine distruberter , carb , plugs , wires and I re torqued the intake It's a built 302 Mallory ignition everything auto trans Elderbrock carb
Yzfoxracer is offline   Reply With Quote
Old 10-14-2013, 09:49 PM   #2
Roguestang's Avatar
Egr? Vacuum leak? You can spend a lifetime chasing these kinds of issues unfortunately.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 10-14-2013, 09:57 PM   #3
Vac leaks, dizzy going out, coil is bad, vac leak... also if the person who built it just slapped it together you could have anything from valvetrain issues to blowby.
2000 Mustang GT Steeda #0048
Old 10-14-2013, 10:08 PM   #4
5.oh's Avatar
I'd check what rogue stang said first, possibly even run the codes even if it doesn't have a check engine light on it'll still come up history codes.. That is if the previous owner or you have not disconnected the battery to reset the computer.
5.oh is offline   Reply With Quote
Old 10-15-2013, 02:18 PM   #5
Yzfoxracer's Avatar
its a 1971 boss 302 lol it doesn't have egr lol
---------- Post added at 03:16 PM ---------- Previous post was at 03:15 PM ----------
coil is brand new, what's a dizzy, and my dad and grandpaw built it
---------- Post added at 03:16 PM ---------- Previous post was at 03:16 PM ----------
lol it's from 1971 so it's not gonna have codes
---------- Post added at 03:18 PM ---------- Previous post was at 03:16 PM ----------
And my dad and his dad built the hole car they are the ones who put it in and they're only second owners they have had it sence the 80s
Old 10-15-2013, 03:17 PM   #6
Roguestang's Avatar
Lol Well that info would have been nice from the get-go, but did you check for a vacuum leak?
Old 10-15-2013, 06:33 PM   #7
Yzfoxracer's Avatar
lol sorry and no so how should I check it?
Old 10-15-2013, 10:43 PM   #8
Roguestang's Avatar
There's a few different ways to check it, but I've always used a little propane around the vac lines. If the idle smooths out, then you can usually figure out where the leak is. But its still a guess since you say it happens only at idle. I'm assuming its carbed, which I'll admit I'm not real familiar with, but could it be possible your not getting enoigh fuel at idle? Maybe the jets need to be adjusted? I'm just brainstorming here.....lol
Old 10-16-2013, 06:50 AM   #9
Yzfoxracer's Avatar
yeah it's adjusted fine lol and it's a brand new carb
Old 10-16-2013, 04:09 PM   #10
Yzfoxracer's Avatar
http://youtu.be/ASDQF5zycfU
Old 10-16-2013, 04:14 PM   #11
Yzfoxracer's Avatar
okay so I checked the vacuum it's all fine the tree was a little loose so I took it off and put some Teflon tape on the threads and tighten the back up and there's only two vacuum lines. Ones from the valve cover to the carburetor and the other is from intake to see the brake booster so it's not vacuum.
Old 10-16-2013, 04:41 PM   #12
DK Racing's Avatar
get a small hose about 2 ft long and place it in your ear then put the other end around the carb base and follow around the intake if their is a leak you will hear it thru the hose. does this motor have vacuum advance?
DK Racing is offline   Reply With Quote
Old 10-16-2013, 05:27 PM   #13
Yzfoxracer's Avatar
ok and I'm not sure how do I tell
Old 10-16-2013, 05:32 PM   #14
DK Racing's Avatar
you will hear a definete sound if you get the end of the hose by a vacuum leaf just like a stetha scope
Old 10-16-2013, 05:56 PM   #15
Roguestang's Avatar
After watching the video, what a nice car!
So looks like its only doing it when in gear. I'm wondering if its a tranny issue? Maybe the torque converter or something isn't right. How's the fluid level?
Old 10-17-2013, 11:07 AM   #16
Liebert91stang's Avatar
I agree with rouge.i don't think it motor because it does it in gear like maybe something bent.i would start looking under the car
Liebert91stang is offline   Reply With Quote
Old 10-17-2013, 11:40 AM   #17
351stroker's Avatar
How about the harmonic balancer. I have seen it twice in the last while. Guys build a motor and just slap on parts without realizing. Two guys had the wrong balancers. Idled good ran like **** and shook like hell in the street.
351stroker is offline   Reply With Quote
Old 10-17-2013, 11:54 AM   #18
Roguestang's Avatar
Possible too. Once the engine is under load, it can act differently.
Old 10-17-2013, 01:35 PM   #19
Yzfoxracer's Avatar
yeah but it ran great before
Old 10-18-2013, 08:48 AM   #20
351stroker's Avatar
balancers wear out buddy.
Old 10-18-2013, 03:37 PM   #21
foxbox's Avatar
I aint your buddy guy...sorry I couldnt help myself
foxbox is offline   Reply With Quote
Old 10-18-2013, 05:16 PM   #22
Yzfoxracer's Avatar
lol is cool man haha
06:55 PM
