Bad hesitation - Mustang Evolution
Old 10-19-2013, 09:25 PM   #1
Minus2380's Avatar
Bad hesitation
I have a hesitation at part and WOT and heard that if I reset the ecu it would help. I cleaned the maf and tb. How do I go about the reset process IF that's the case?
Minus2380 is offline   Reply With Quote
Old 10-19-2013, 09:42 PM   #2
Roguestang's Avatar
You can disconnect the battery for 20 mins or so. That should reset the computer. Fixing your hesitation issue, may be an entirely different question though. Good luck!
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 10-19-2013, 10:12 PM   #3
Resetting the ECU= disconnecting the battery and touching the terminals together. But I doubt your idle issue will be solved by a ECU reset.
2000 Mustang GT Steeda #0048
Old 10-19-2013, 10:32 PM   #4
Minus2380's Avatar
I have good idle, it's only in second and above that the loss of power happens. First gear is good. I don't know what's up?!?!?
Old 10-20-2013, 03:23 PM   #5
Roguestang's Avatar
It could be that in First gear, your going by the rpm range where you notice the hesitation too quickly. I've seen that happen before. It could still be there, you just don't notice it.
Most times when there is a hesitation or starting issue, its best to trouble shoot starting with spark or fuel.
Old 04-07-2014, 11:55 PM   #6
StangLife209's Avatar
I have the same problem but when i stop its when it said go hesitate and the RPMs start to move a little? I clean throttle body changed sensors and still doing it?? help please
StangLife209 is offline   Reply With Quote
Old 04-07-2014, 11:56 PM   #7
It hesitates when im at a light stoped
« 88 hesitation | MAF »
01:45 PM
