Gt40 heads - Page 2 - Mustang Evolution
Old 10-28-2013, 07:41 PM   #36
94gtconvert's Avatar
Intake manifold should fit fine. The P heads are as good as the GT40s but you have to worry about header clearance and also the spark plug angles require custom or 90 degree boots and heat socks on them. Lots of guys run the P heads though, FRPP headers fit fine on them.
I took the valve cover off one side to day and they are GUNKED. Hopefully no damage is done, I plan on getting them rebuilt anyway. I also did a lot of research and the header problem has been thrown around a lot. I heard the gt-40p heads are better in terms combustion, but gt-40's can handle higher lift cams. I'm not going for sound but power. Should I hold off and get gt-40's or get these P's for practically free but have to get them rebuilt?
94gtconvert is offline   Reply With Quote
Old 10-28-2013, 07:51 PM   #37
The power difference is negligible. I'd go with the non p heads if I had a choice but if you can get them for free you can't beat free.
2000 Mustang GT Steeda #0048
Old 10-28-2013, 08:40 PM   #38
Agreed
Old 10-28-2013, 09:09 PM   #39
harryb5a4's Avatar
Region: West Virgina
There is a guy around my area that has a 99 exploder motor 5.0 with pheads pulled from running car with less than 100,000 miles 300 bucks
harryb5a4 is offline   Reply With Quote
Old 10-28-2013, 09:57 PM   #40
I may be getting the heads and intake for free. But good looking out. If it turns out I can't have them then I will continue looking for gt-40's non p
Old 10-29-2013, 12:29 AM   #41
badsheep5.0's Avatar
http://www.mustang50magazine.com/tec...ormance_combo/
I think I might go this route
badsheep5.0 is offline   Reply With Quote
Old 10-29-2013, 09:13 AM   #42
Lots of issues with Patriot Performance. Google it.
Old 10-29-2013, 08:55 PM   #43
Damn looked so promising
Old 10-30-2013, 08:26 AM   #44
Not sure why you'd need porting on a stock bottom end 302 anyway. Not worth it to port GT40s and a 302 bottom end will not need any more air than the TFS heads can provide box stock.
Old 10-30-2013, 10:49 AM   #45
If I go through with these P heads witch I most likely will, what size injectors should I get. I also would want to put a bigger mass air meter, tb, gears, fuel rail/ pump, and headers. I saw a YouTube video and the guy said 94/95 computers like to fight you when you put a cam in, should I also buy a new computer or have my stock one tuned or buy a bamba chip? Idk how to go about tuning it do I need a A9L fox computer?
Old 10-30-2013, 12:34 PM   #46
No you do not need a fox computer, a good tuner can tune the 94/95 computers just fine. If staying NA the stock fuel system should be fine. I'd go with a 70mm TB, 73mm MAF and longtubes for the 5.0 motor.
Old 10-30-2013, 01:58 PM   #47
Dion11197's Avatar
For long tubes on the p heads, I hear the BBK's work fine..... May have to machine a spark plug socket to fit the tight clearance, but other than that they're good. I've got BBK LT's on mine and pick up my p's from the machine shop this week, so I'll let you know how the fit is.
Dion11197 is offline   Reply With Quote
Old 10-30-2013, 06:54 PM   #48
ok thanks
02:00 AM
