AOD transmission in SN95? - Mustang Evolution
Old 10-25-2013, 01:26 AM   #1
lemons95's Avatar
Will the older AOD transmission fit in a SN95 using the AODE crossmember?(will a 79-93 crossmember work)
Will the shifter fit in the same place?
The drive shaft will need to be longer.
I'm doing a carbureted 5.0 swap, have the engine and have found all the parts either online or locally.
Already have an 8.8 rear end.
And as a little side question does anyone know if the existing ignition system will work with a carbureted engine?
06:55 PM
