1991 GT bucking problem - Mustang Evolution
Old 10-27-2013, 10:56 PM   #1
PhilDladu's Avatar
I have a 5.0 1991 lx mustang and have a big bucking problem. It is bucking over 2500-3000 rpm and I'm loosing a lot of power. Even at 1500-2000 rpm, if I pull the gaz little too much, it is bucking as hell. I don't know what to do ! I changed my fuel filter, my coil pack is fine (no sparks when I throw water on it) and my engine seems to be grounded on the body. My idle is also little too high even when the engines hot (1200-1300rpm). My car has been made in usa. It's a manual transmission. Any ideas? Sorry for my bad english.
PhilDladu is offline   Reply With Quote
Old 10-27-2013, 11:22 PM   #2
Fiveohfox's Avatar
Spark plugs/wires, MAF?
Fiveohfox is offline   Reply With Quote
Old 10-27-2013, 11:30 PM   #3
PhilDladu's Avatar
New sparkplugs (stock ones), msd distributor (streetfire) and wires recently changed but the car was doing it before these changes. MAF is stock... I think.
Old 10-28-2013, 01:14 AM   #4
Fiveohfox's Avatar
That's weird idk then cause when mine was doing it, I changed the fuel filter, plugs and wires and it went away.
Old 10-28-2013, 06:49 AM   #5
mystang50's Avatar
could possibly be harmonic balancer
Old 10-28-2013, 09:26 AM   #6
PhilDladu's Avatar
Oh and I forgot to say that the problem is less important when the engine is cold... It is still missing power but it is less bucking... And I think it's doing backfires sometimes but i'm not really sure and it's not happening very often.
Old 10-28-2013, 01:34 PM   #7
Jlp06's Avatar
Region: Utah
Clean your MAF sensor with some CRC cleaner at your local autozone. Next I would check your CATs for back pressure and also check your EGR valve for carbon buildup. Has your thermostat ever gone out?
---------- Post added at 12:34 PM ---------- Previous post was at 12:32 PM ----------
Also, how's your air filter? May need to change that
Jlp06 is offline   Reply With Quote
Old 10-29-2013, 10:54 AM   #8
PhilDladu's Avatar
I dont know, I recently bought this car. Is it possible it's my fuel pump ? Or that it's related with the fuel pressure ?
Old 10-29-2013, 11:50 AM   #9
Jlp06's Avatar
Region: Utah
Well, turn your key on but not enough to start it. You should hear the fuel pump kick on.
Old 10-29-2013, 11:55 AM   #10
PhilDladu's Avatar
If it does, my problem is the fuel pump?
Old 10-29-2013, 12:50 PM   #11
Liebert91stang's Avatar
The fuel pump should kick on when the key is turned.you want to hear that.doesnt sound like it fuel related to me
Liebert91stang is offline   Reply With Quote
Old 10-29-2013, 01:00 PM   #12
Durnstang's Avatar
Can you rev the car while parked? And it feels fine?
You have to check for spark New plugs or not
Change your fuel filter and check your timing once you know those are good move on to sensors
Spark, timing, fuel
Durnstang is offline   Reply With Quote
Old 10-29-2013, 01:16 PM   #13
PhilDladu's Avatar
No he's not better when parked... My timing is good, spark plugs and fuel filter are new...
Old 10-29-2013, 01:42 PM   #14
Durnstang's Avatar
Sorry I should have read your post better
Did the high idle start the same time the power loss started
Old 10-29-2013, 01:51 PM   #15
Durnstang's Avatar
Also check the maf just unplug it whilethe car is off then start if the car runs at all better it points to a failed maf
Old 10-29-2013, 01:57 PM   #16
2300turboford's Avatar
Does the car have a cam ? And is it a 5 speed ?
Old 10-29-2013, 02:13 PM   #17
Durnstang's Avatar
haha are you going where I think you are
Old 10-29-2013, 02:16 PM   #18
PhilDladu's Avatar
No he's stock and yeah its a 5 speed. And i don't really know if the problem started at the same time but i know that even if i changed the timing, the idle didnt drop..
Old 10-29-2013, 02:27 PM   #19
Durnstang's Avatar
Do the simple maf test unplug while off then start it'll run better if maf has failed
Old 10-29-2013, 04:36 PM   #20
mustangmania91's Avatar
I own a 91 GT also. Sounds like the same problem I had with mine. I changed the TFI ignition module on your distributor and never had it happen again
mustangmania91 is offline   Reply With Quote
Old 10-30-2013, 08:54 AM   #21
PhilDladu's Avatar
I heard this in a lot of forums, I will try this out! Thank you guys, I will bring you news soon!
Old 10-30-2013, 09:32 PM   #22
PhilDladu's Avatar
Thanks to all of you guys, i cleaned my maf sensor and it's a new car !!
08:15 AM
