Help me out guys - Mustang Evolution
Old 10-28-2013, 04:20 PM   #1
Polo_FiveOh's Avatar
Help me out guys
Well a week ago I went into my car and tried to start it and it didn't crank. So I noticed the connectors for my alternator was burnt out (how I didn't notice I have no clue) but turns out I needed a new alternator bought one and then the car cranked. But no start so then I ended up needing a new battery also. With my luck. Then after all that it started up no problem. On the highway I noticed a battery sign on my dash. And I have no idea what it could be now. Anyone ever had this issue or has a clue. If your lost on the story just let me know ill clarify. Tried to make it as short as possible lol.
Polo_FiveOh is offline   Reply With Quote
Old 10-28-2013, 04:40 PM   #2
03Graymach's Avatar
Check the wiring on the alternator and make sure they are all good and tight if so check the wireis them selves to make sure the ends are sill getting a good connection
03Graymach is offline   Reply With Quote
Old 10-29-2013, 05:57 AM   #3
I checked them and nothing. The car completely died out last night I had to tow it home.
Old 10-29-2013, 07:51 AM   #4
03Graymach's Avatar
Have you checked all your fuses
Old 10-29-2013, 10:36 AM   #5
DustyStang306's Avatar
The red battery light on the dash means your alternator isn't charging your battery I would check the grounds the ground that goes on your battery could be bad
DustyStang306 is offline   Reply With Quote
Old 10-29-2013, 10:42 AM   #6
What if my ignition housing is cracked a tiny bit. Because I just noticed it today
Old 10-29-2013, 10:51 AM   #7
Maybe but I couldn't see how and like I said I'd be checking the grounds
Old 10-29-2013, 10:52 AM   #8
03Graymach's Avatar
And maybe take a wire brush and take it to all the ends of the wires and to the frame where the ground connects at
Old 11-07-2013, 10:47 AM   #9
351stroker's Avatar
+1 to grounds. Also check the battery clamps themselves. I had my 85 F150 stump me all summer one year and replaced every electrical component until someone told me to just replace the clamps and man was i pissed. $7 worth if clamps as compared to $400 in everything else.
351stroker is offline   Reply With Quote
06:34 AM
