Pro-m 3" pro tube - Mustang Evolution
Old 10-28-2013, 04:41 PM   #1
92coupe's Avatar
Pro-m 3" pro tube
As anyone here run one of these on a turbo setup. Will it work like a regular maf upgrade as in if I throw on a 24lb calibrated maf and 24lb injectors it should fire right up?
92coupe is offline   Reply With Quote
Old 10-29-2013, 07:13 AM   #2
92coupe's Avatar
Or what would need to be done to convert a lightning maf to be run as a blow thru
Old 10-29-2013, 07:45 PM   #3
Lapida's Avatar
You can make your own blow thru setup. Need the 3" straight tube and the mass air flange. Check the compatibility of the lightning maf with the flange because the incorrect flange will cause boost leak. I paid for the flange $50, maf $175, tube $20, welding $10.
Lapida is offline   Reply With Quote
Old 10-29-2013, 09:44 PM   #4
92coupe's Avatar
The flange for a lightning maf is the small pattern tonsil style isn't it?
Old 10-30-2013, 04:27 AM   #5
Lapida's Avatar
This one?
Old 10-30-2013, 06:45 AM   #6
92coupe's Avatar
Old 10-30-2013, 06:45 AM   #7
92coupe's Avatar
I don't see much difference in those two
02:56 AM
