1995 GT 5.0 convertible automatic - Mustang Evolution
Old 10-29-2013, 01:06 AM   #1
jamie.1019's Avatar
Having a blown fuse issue
The horn, cruise control, taillights all are not working i found a blown fuse under the hood. Have replaced a handfull of times, but after a few hours of driving the fuse blows?
Any ideas?
ID:	134298   Click image for larger version
jamie.1019 is offline   Reply With Quote
Old 10-29-2013, 11:28 AM   #2
My guess would be a bad ground, check ALL of your grounds, redo the main engine ground etc...
Old 10-29-2013, 11:38 AM   #3
Durnstang's Avatar
If it always the same fuse it's something in that circuit, start checking for corroded or loose and rubbed through wires it can be a pain
Durnstang is offline   Reply With Quote
Old 10-29-2013, 11:48 AM   #4
Durnstang's Avatar
Also start with tai lights they generate heat and are used the most if there's a short back there that'll blow the fuse
Old 10-29-2013, 11:50 AM   #5
I chased down a wiring gremlin for months... MONTHS... And when you finally find it you are just like... "whhhhyyyyy!!!!" because its something that you can often just fix in 10 minutes for 5 bucks.
Old 10-30-2013, 01:40 AM   #6
jamie.1019's Avatar
Thank you all i will let ya know.
07:49 AM
