Starting problem - Mustang Evolution
Old 10-30-2013, 02:31 PM   #1
Region: West Virgina
Starting problem
Hey guys I have 88 mustang gt auto . The car starts and runs fine when its warm but when the tempr is freezing or colder the car turns over just wont start soon as the temperature warms up it start right up any suggestions
Mustangnutz is offline   Reply With Quote
Old 10-31-2013, 01:10 PM   #2
Anybody
Old 10-31-2013, 01:11 PM   #3
02GTvert's Avatar
How old is your battery?
02GTvert is offline   Reply With Quote
Old 10-31-2013, 01:18 PM   #4
Brand new
Old 10-31-2013, 01:20 PM   #5
02GTvert's Avatar
Let me search a little and I'll get back to you..I don't know and doesn't look like anyone is chiming in at the moment.
Old 10-31-2013, 01:23 PM   #6
Thanks appreciate any help
Old 10-31-2013, 01:23 PM   #7
02GTvert's Avatar
Something simple I didn't think about...what kind of battery? Each battery is different and turn out a different amount of cranking amps at different temps...possibly a weak starter and cold cranking amps could be the problem.
Hmm but turns over....
Old 10-31-2013, 01:58 PM   #8
Turns over fine just wont start its an interstate battery
Old 10-31-2013, 02:01 PM   #9
02GTvert's Avatar
Where's the older guys at!?
Old 10-31-2013, 02:13 PM   #10
I know
Old 10-31-2013, 04:04 PM   #11
Liebert91stang's Avatar
Sometimes corrosion plays a factor.battery post,solonoid relay....
Liebert91stang is offline   Reply With Quote
Old 10-31-2013, 04:11 PM   #12
also if the weather is really cold any car will have hard start.oil is thinker and gas doesn't evaporate when it's freezing.not sure where you live
Old 10-31-2013, 04:11 PM   #13
Got everything clean
Old 10-31-2013, 05:18 PM   #14
Fuel filter good?
Old 10-31-2013, 05:46 PM   #15
Yes new fuel pump filter everything is new
Old 11-05-2013, 12:05 PM   #16
351stroker's Avatar
plugs?wires? Coil?
351stroker is offline   Reply With Quote
Old 11-05-2013, 12:46 PM   #17
Ill try that i've tryed everything else thanks
Old 11-05-2013, 01:51 PM   #18
351stroker's Avatar
sometimes a new set of wires makes a world of difference.
Old 11-05-2013, 04:51 PM   #19
Ok ill try that tomorrow
Old 11-08-2013, 09:09 AM   #20
jduckz5.0's Avatar
Your fuel pressure might be a touch low...try turning key on/off a couple times before starting...check your distributor cap could be loose or cracked allowing moisture to build..check plugs are capped properly...
jduckz5.0 is offline   Reply With Quote
08:12 PM
