95 GT wont shut off - Mustang Evolution
Old 11-03-2013, 11:49 AM   #1
02silvermonster's Avatar
95 GT wont shut off
I just bought this car turned it on the ignition got stuck in the start portion the started turned a few extra times the won't shut off played with it got it to turn off, car stays in the on position had to disconnect the battery changed the lock cylinder but the won't turn to the off position could it be the ignition switch? and the whole steering wheel has to come apart for that?
02silvermonster is offline   Reply With Quote
Old 11-08-2013, 09:31 AM   #2
jduckz5.0's Avatar
This happened to me in my f150...when you turn the key a plastic slide piece goes up n down for on/off...the rod n spring in column break sometimes causing it not so spring back or get stuck...either column has to be taken apart and fixed or the much easier and cheaper way of go to junk yard and get a new steering column...
jduckz5.0 is offline   Reply With Quote
Old 11-09-2013, 03:15 PM   #3
Varasios's Avatar
The solenoid on my starter got stuck and caused this to happen on mine.. Replaced the ignition cylinder and got a powermaster starter and all was good.. I was worried i had to take apart my column but that wasnt the case for my issue.
My starter fried on me when it got stuck
Varasios is offline   Reply With Quote
Old 11-09-2013, 03:32 PM   #4
Liebert91stang's Avatar
Originally Posted by Varasios View Post
The solenoid on my starter got stuck and caused this to happen on mine.. Replaced the ignition cylinder and got a powermaster starter and all was good.. I was worried i had to take apart my column but that wasnt the case for my issue. My starter fried on me when it got stuck
+1 solonoid stuck on mine before.seem to only happen when it was cold out
Liebert91stang is offline   Reply With Quote
Old 11-10-2013, 06:46 AM   #5
Old 11-10-2013, 08:03 AM   #6
jduckz5.0's Avatar
Yep that's the liitle rod...was it a pain to get out??? On my truck it was easier to get a column...
Old 11-15-2013, 03:37 PM   #7
It wasn't hard to take out but very time consuming. and when I put it back together idk if the spring before the clock spring has to be pressed in or not
Old 11-15-2013, 04:20 PM   #8
jduckz5.0's Avatar
I'm not completely sure but I think the spring will press from just ignition lock...the spring and shaft is exposed towards the bottom of column so try holding there with a screw driver when installing ignition lock...
Old 11-15-2013, 09:11 PM   #9
it's the spring on the shaft right behind the clock spring there is a snap ring and a plastic piece that holds the spring in
06:16 PM
