new to this, need some help. - Mustang Evolution
Old 11-08-2013, 12:26 AM   #1
Alright mustang evolution. Recently bought a 1989 mustang 5.0 about 2 months ago. Want to build it so it hits low 12s. Help!!! Because I have no idea what to do with the engine. Any suggestions??
jgodi23 is offline   Reply With Quote
Old 11-08-2013, 11:24 AM   #2
Sgt_Syke's Avatar
Do u want to use the 302? Or are you going to swap in a 351? What else will you do with the car...daily driver, track only, etc. what is your budget? If you want low twelves, you can get there pretty easy, but a lot depends on how much you wanna spend. Is it auto or manual? Lots of questions need answered first.
Sgt_Syke is offline   Reply With Quote
Old 11-08-2013, 11:54 AM   #3
Wattup Sgt_syke. Yea I want to keep the 302. And naw no track I just want a daily driver so I can smoke these chumps around my town. My budget is real good though so I can pretty much spend watever. And yes it is manual.
Old 11-08-2013, 01:27 PM   #4
Skulls98GT's Avatar
First things first. ME rules are... Can't talk about street racing. So... With that out of the way, many people on here will help you spend your money to make a track car that you can drive daily.
---------- Post added at 02:27 PM ---------- Previous post was at 02:25 PM ----------
Do you want to stay naturally aspirated, or go forced induction?
Skulls98GT is offline   Reply With Quote
Old 11-08-2013, 01:27 PM   #5
Skulls98GT's Avatar
Old 11-08-2013, 01:49 PM   #6
Ight man gotcha. And if track car can be made thats koo too. But mostly daily driver. And naw no forced induction. Naturally aspirated.
Old 11-08-2013, 03:21 PM   #7
Skulls98GT's Avatar
NA = harder to obtain and probably more $$ but worth it in the end.
Old 11-08-2013, 03:28 PM   #8
jduckz5.0's Avatar
How many miles are on your 302 now???if it's healthy stroke it, get a h/c/i top end kit,bigger maf,gears,and stiffen up chassis n suspension...
jduckz5.0 is offline   Reply With Quote
Old 11-08-2013, 03:47 PM   #9
Okay skulls98 gt thanks. Hey jduckz5.0 yea that sounds like a good way to go ima look into that. Not sure how healthy my motor is right now. It has about 110k. Thanks
Old 11-08-2013, 04:29 PM   #10
jduckz5.0's Avatar
In my old lx I had just a bored .030over 302 with Holley systemax 2 top end kit,373 gears,auburn posi,big maf,frt coilovers,rear adj. Lcas,sfc,and forget clutch brand but I ran 12.4 consistently..still had ac unit and full weight...volleys cam is better for a blower so I think I could of picked some et if I would of had a better cam for na...
---------- Post added at 07:29 PM ---------- Previous post was at 07:27 PM ----------
Forgot 24lb injectors and 190lph fuel pump..lol I think that's it..
Old 11-08-2013, 05:03 PM   #11
Lol Sounds good though. Ima look into that setup for sure. Thanks alot jduckz5.0 appreciate it.
Old 11-09-2013, 04:56 PM   #12
Sgt_Syke's Avatar
Pretty much what everyone is saying...stroke it, heads, cam, maf, exhaust, gears, stiffen chassis. When you have more questions...we're here!
Old 11-09-2013, 10:54 PM   #13
First off, build a 351 instead of a 302 stroker. Cost is nearly the same and the returns on the 351 based stroker are much, much higher. Its practically a direct bolt in.
Second, what is your budget? To build any sort of good 302 or 351 stroker you are looking at $5k+ for the motor itself not even getting into the driveline/chassis/suspension and fuel system. Even a basic top end HCI kit is going to run $2800.
Third, a 12 second car is quick but not exactly the fastest thing in the world. You can hit 12s with just bolt ons, gears and a lot of weight reduction in a 5.0 Fox which is where I would suggest you start. Bolt ons, 3.73 gears, advance timing to 14 degrees, do some basic suspension and sticky tires and see what she runs. You might be surprised. If you still aren't happy at that point do the fuel system and throw a 125 shot at it for 11s.
What I would do if I were you is just research a LOT. Make an account on other sites too and search here and over there, any question you can think to ask has already been answered if you look.
03:07 AM
