Antifreeze for 95 GT 5.0 - Mustang Evolution
Old 11-10-2013, 12:17 PM   #1
Region: Nebraska
My low coolant light is on. What kind of antifreeze is the best for my Stang? Thanks!
MustangSue is offline   Reply With Quote
Old 11-10-2013, 04:07 PM   #2
badsheep5.0's Avatar
I but the premixed kind do you have a small leak
badsheep5.0 is offline   Reply With Quote
Old 11-10-2013, 05:25 PM   #3
jduckz5.0's Avatar
Good old fashion green antifreeze like prestone...do not buy pre mix...your paying for them to add water...lol hence you only get half the antifreeze for $2 dollar savings...
jduckz5.0 is offline   Reply With Quote
Old 11-10-2013, 05:32 PM   #4
True but I keep that one in my trunk I have a very slow leak I have not been able to find
Old 11-12-2013, 09:25 AM   #5
surfinglbi23's Avatar
Are you seeing any puddles on the ground? Sometimes antifreeze can "run" so if you find the leak, you can atleast trace it back. I had a rear main seal leak on my old Jeep, took forever to find because it was trickling down and hitting the drive shaft, spraying fluid everywhere so made it tough to find.
surfinglbi23 is offline   Reply With Quote
Old 11-12-2013, 12:16 PM   #6
It's right up front by the plastic tank and the radiator I have read the plastic tanks go bad sometime and it's always a real small puddle it is also only some times
Old 11-12-2013, 12:55 PM   #7
Yea I've heard those tanks can go bad - not a bad idea to check it.
Old 11-12-2013, 01:00 PM   #8
I might buy the aluminum one from am and replace al the hoses to it here soon
12:29 AM
