Aluminum heads - Mustang Evolution
Old 11-11-2013, 02:22 AM   #1
M3no956's Avatar
Aluminum heads
Does anyone know what heads these are, I saw it stamped on an engine I wanna buy and the owner only knows their aluminum
ID:	135993   Click image for larger version
M3no956 is offline   Reply With Quote
Old 11-11-2013, 06:36 AM   #2
jduckz5.0's Avatar
Ths is a dodge head...I don't know..ant othe stamps on them???
jduckz5.0 is offline   Reply With Quote
Old 11-11-2013, 06:56 AM   #3
jduckz5.0's Avatar
Could be older trick flow heads I think they came with tfs but that looks like ths...
Old 11-12-2013, 06:55 AM   #4
I'd be guessing Pro Comp Chinese copypasta heads.
Old 11-12-2013, 08:03 AM   #5
M3no956's Avatar
Are they any good? And well it also has a trick flow stage 2 cam
Old 11-12-2013, 08:18 AM   #6
Pro comps are a cheap knock off brand like the Pro Products stuff. If its running well I'd just leave it alone.
Old 11-12-2013, 08:22 AM   #7
M3no956's Avatar
Oh ok and well everything works good on it, I've already driven the car
Old 11-12-2013, 08:50 AM   #8
Ok well just so you know they're definitely a knock off. AFR/TFS/Eddy etc... make damn sure you know they are their heads and the names will be stamped on the front of the head right in the same spot as those.
What does the guy want for the car if you don't mind me asking? Who tuned it? Who built the shortblock etc... I'd be very leery of buying a modded car from an owner who doesn't know wtf he has unless you get it for a song.
Old 11-12-2013, 03:43 PM   #9
Liebert91stang's Avatar
I agree with Scotty.better find out more about it before you get into a lemon
Liebert91stang is offline   Reply With Quote
Old 11-12-2013, 04:41 PM   #10
Actually re-read the post and I think he just wants to buy the engine. I'd pass unless the guy knows exactly what is in it or you are getting it for a few $hundred.
Old 11-12-2013, 06:02 PM   #11
You can buy new tf intake for about 500 and a stage 2 for around 2 give or take.my opinion if you can get it for few hundred you will be doing good
Old 11-12-2013, 06:40 PM   #12
M3no956's Avatar
Ok well the engine is a 307 forged internals,1.7 rollers rockers, hardened pushrods,longtube headers,upgraded valve springs,trick flow stage track heat upper lower and also the trick flow stage 2 cam , idk what brand of aluminum heads, 70mm tb with a 76mm maf with 24lbs injectors, has smog pump,powersterring, a/c canceled and also comes with a nitrous wet kit but not installed
Old 11-12-2013, 06:46 PM   #13
The big kicker here will be the price of it. Those are very probably the procomps I think they are which are OK if the installer checked them out and cleaned up anything that might have been an issue.
However I still would pass on it unless you get it for a REALLY good price.
Old 11-12-2013, 06:50 PM   #14
M3no956's Avatar
And well he's not selling the car only engine and Trans cause he's doing an lsx swap, and well the guy who built the motor and owns the car is from Mexico but right now he has it at a friends shop locally and I'm not sure if it's tuned or not
---------- Post added at 08:50 PM ---------- Previous post was at 08:48 PM ----------
He's wanting like 2gs I believe but I think I can lower him down to 1,500
Old 11-13-2013, 07:00 AM   #15
$1500 for that?
I've got some property for sale in upstate NY if you are interested...
Old 11-13-2013, 07:13 AM   #16
ColeJohnson's Avatar
Wait. I understand now!
He meant 2000 pesos. That's a better price.
2016 Comp Orange GT (current)
Old 11-13-2013, 07:32 AM   #17
Last time I was in Turkey I had an awful lot of Lira in my account...
In all seriousness... that is an unknown motor built by someone in their backyard and you have no clue about how good or bad that guy is. Also the fact that they used Pro Comp heads should tell you something about the quality of components in the rest of the engine. Even when I was doing my mega budget build I made it a point to get a good name brand set of heads.
Old 11-13-2013, 09:14 AM   #18
M3no956's Avatar
Oh ok thanks for the info looks like I won't be buying it
07:43 PM
