Valve train! Need some help - Mustang Evolution
Old 11-12-2013, 05:41 PM   #1
Shifty 5.0's Avatar
I have a 302 and there is a cam in it but don't know what kind. I'm about to buy the AFR 165 heads and comp cams roller rockers but my question is what pushrod length should I use? And what are some good lifters?
Shifty 5.0 is offline   Reply With Quote
Old 11-12-2013, 06:16 PM   #2
Liebert91stang's Avatar
Need to buy tool to check pushrods length
---------- Post added at 07:16 PM ---------- Previous post was at 07:11 PM ----------
and if they are roller lifters most people don't change them
Liebert91stang is offline   Reply With Quote
Old 11-12-2013, 06:23 PM   #3
Stock lifters are fine to re-use. Pull the cam and look for markings, if not then buy a cam that you are comfortable with rather than using an unknown.
And yes, you HAVE to measure for proper pushrod length, there is NO other option and nobody will be able to tell you the right length except you and that tool.
02:28 AM
