ground strap placement - Mustang Evolution
Old 11-13-2013, 04:31 PM   #1
3stangs's Avatar
Well after a week of intermittent not starting I've zeroed in on one problem. My ground strap from the motor mount to the chassis is broke. So I got some new strap from work to replace it. Problem is I can't the nut off the motor mount. Can I just move it from the mount to the one on the timing cover? Also I'll be moving the other end closer, any clean spot on the chassis will work correct?
3stangs is offline   Reply With Quote
Old 11-14-2013, 07:27 AM   #2
That nut should come off but yeah any point should work. I also would not use another replacement strap, I used 0 gauge battery cable when I re-did mine and I added one to the passenger side too.
Old 11-14-2013, 07:33 AM   #3
3stangs's Avatar
Oh it'll come off with the right tools and effort. Which I don't have at home and it's cold and windy so I don't like being out on the ground. Lol. I decided on the strap just to get it done. After reading a bunch of threads from sites I'll be replacing and adding some better grounds
Old 11-14-2013, 12:47 PM   #4
3stangs's Avatar
Got the new ground put on. Now the other culprit, which I suspected from the start also, is the ccrm. When I try to turn it over I can hear the ccrm just buzzing /clicking, and the fan immediately turns on. Is that indicative of it failing? I've thought that was going out also cause sometimes the fan wouldn't turn off after the car was off unless I tapped it.
Old 11-14-2013, 01:41 PM   #5
3stangs's Avatar
Btw it's a 94 gt. Aode trans
04:27 AM
