351w from a bronco - Mustang Evolution
Old 11-15-2013, 06:45 AM   #1
86foxbody's Avatar
351w from a bronco
I found a 351w from a bronco is it good to install that engine into a foxbody what type of modifications would i need to do
86foxbody is offline   Reply With Quote
Old 11-15-2013, 07:56 PM   #2
Slow4V's Avatar
Yeah people do it all the time
Old 11-15-2013, 08:22 PM   #3
Hmiller's Avatar
Send a message via AIM to Hmiller
I know a guy with a fox with one in it ... Actually made the stock hood fit too
VOTE For MOTM!!!!!!
Hmiller is offline   Reply With Quote
Old 11-15-2013, 11:21 PM   #4
86foxbody's Avatar
Is there a another car i can get the engine out of that would be better than the bronco
Old 11-16-2013, 12:03 AM   #5
Hmiller's Avatar
90s model lightning
VOTE For MOTM!!!!!!
Old 11-16-2013, 10:21 AM   #6
Any 94 and up, some 93 models also but not all, f250, lightning, bronco will be roller cam blocks. Any 351 built before then uses a flat tappet cam. They can be converted though with special lifter but they are fairly pricey.
I wouldn't run it as is though. Those motors are built to make peak power down low in the rpm range since they are for trucks, the lightning motor might be better though. I would run the 5.0 and build the 351 on the side, better h/c/i ect.
87fiveoh is offline   Reply With Quote
Old 11-17-2013, 04:13 PM   #7
I used conv fox motor mounts, crown vic oil pan, shims on sway bar, ford motorsport dist gear for roller cam, custom built h-pipe w/ 5.0 headers edelbrock intake under stock hood and cut n welded p/s and a/c brackets back in 94 in an 85gt similar set up in 97 for a 94 gt!! u will love the torque!!
Nitrous is like a hot girl with an STD.... ya know ya want to hit it, but you're afraid of the consequences....
fomoco85 is offline   Reply With Quote
05:38 PM
