is my motor running lean? - Mustang Evolution
Old 11-19-2013, 12:06 AM   #1
1988 5.0 starts and drives but when i step on the gas hard it stutters and dosnt feel right to me and it dosnt idle very well it usually just shuts off. i just got the car and im trying to figure out why its doing this so i dont have to spend a bunch of money on a mechanic. thanks
corey_5.0 is offline   Reply With Quote
Old 11-19-2013, 12:32 AM   #2
87LX306's Avatar
EGR sticking open will make your car have similar symptoms.
87LX306 is offline   Reply With Quote
Old 11-19-2013, 12:41 AM   #3
how would i fix it or close it? i'm kinda new to working on cars thanks
Old 11-19-2013, 03:35 AM   #4
Getn off's Avatar
Sounds like a simple case of old gas. How long has it sat before you got it?
Getn off is offline   Reply With Quote
Old 11-19-2013, 04:17 AM   #5
Liebert91stang's Avatar
Sounds like it the throttle position sensor.mine is doing this as well just haven't fixed it yet.its black and has 2 screws holding it in on the throttle body.about a 30 dollar fix
Liebert91stang is offline   Reply With Quote
Old 11-19-2013, 05:46 AM   #6
mystang50's Avatar
I agree with this.
Old 11-19-2013, 07:19 AM   #7
jduckz5.0's Avatar
When I buy a used car I always change plugs,cap,rotor,oil,fuel filter,coolant,air filter,fill with fresh high octane,etc...have you done any of that??? Spray cleaner in speed density,tube,and throttle body...
jduckz5.0 is offline   Reply With Quote
Old 11-19-2013, 10:18 AM   #8
DustyStang306's Avatar
Well you were just on asking what could happen when the battery cables are put on backwards well you could have some burnt wiring I'd check some of the grounds and other wiring and is there any mods done to it we really need to know more to be able to help better
DustyStang306 is offline   Reply With Quote
Old 11-19-2013, 01:48 PM   #9
It has a after market air filter and a MSD distributor and i think thats it. i also did get it to start with a key i had to take out all the viper alarm system which was a pain in the ***. I also havent filled the tank up since i got it but the guy before me said he filled it up a few times the week i bought it. Im going to try new spark plugs and ill check the EGR valve any other advise?
Old 11-19-2013, 01:53 PM   #10
Throttle position sensor
---------- Post added at 02:53 PM ---------- Previous post was at 02:52 PM ----------
it communicates with the computer on how open the butterfly is open.sptoms are idle surging and shake when you stomp it
Old 11-19-2013, 03:04 PM   #11
it just stutters and dosnt really do anything. can i just take my EGR valve off or is there stuff i have to do after taking it off?
Old 11-19-2013, 04:53 PM   #12
Easiest to replace it.if you do take it off you need to plug it but it has no hp loss/gain.helps with gas mpg also
Old 11-19-2013, 04:56 PM   #13
ayy bro thanks for your help ima try to clean it and if that dosnt work ill buy a new one.
09:24 PM
