help 85 - Mustang Evolution
Old 11-20-2013, 08:01 PM   #1
SamChildress's Avatar
help 85
I have a 85 5.0 a/t all stock car floods/bogs out around 1800rpm to 2200rpm while driving many new parts I can list them all if wanted or needed
SamChildress is offline   Reply With Quote
Old 11-21-2013, 07:01 AM   #2
mach5894's Avatar
Is this running it cold?
mach5894 is offline   Reply With Quote
Old 11-21-2013, 09:18 AM   #3
Sgt_Syke's Avatar
List what you have done...parts. I'm leaning towards carb issue.
Sgt_Syke is offline   Reply With Quote
Old 11-21-2013, 12:38 PM   #4
It runs fine when its cold or in park just once it gets warm it dose it and not all the it wil run good one day then crappie the next
And ill list all the parts in a min
Old 11-21-2013, 02:19 PM   #5
Skulls98GT's Avatar
So it runs fine at 2200+ ?
I'm thinking carb problems as well. Could be plugged low speed jets.
Skulls98GT is offline   Reply With Quote
Old 11-21-2013, 02:23 PM   #6
No that's when it will bog slash flood out and its that dumb cfi/tbi
Old 11-21-2013, 02:32 PM   #7
Here's a list of new parts
Tbi gasket kit
Tps sensor
Fuel pressure reg
Fuel filter
Valve cover gaskets
Coolant temp sensor
Spark plugs
Spark plug wires
Thermo 195
Map sensor
Timming done 2x
Coil
And iam sure missing a few things
Can't remember wats this is called
And there's prolly more
Old 11-23-2013, 07:34 PM   #8
lx92coupe's Avatar
The 1985 automatic is a throttle body injection, not a carb. Might be able to pull codes somehow. The manual tranny cars were a holley 4bbl. with more hp than the auto. You might just swap out the manifold and put a carb on it.
2013 GT Roush Stage1 TVS
lx92coupe is offline   Reply With Quote
Old 11-23-2013, 09:06 PM   #9
Liebert91stang's Avatar
Sounds like the injectors could be stopped up
Liebert91stang is offline   Reply With Quote
Old 11-23-2013, 09:15 PM   #10
an I agree with 92 coupe may want to carb it
Old 11-24-2013, 09:25 PM   #11
I got it fixed it was the wires running to the o2 sensor had melted to the exhaust manifold
Old 11-25-2013, 05:07 AM   #12
Good find
09:34 PM
