Easiest way to bleed front brakes?? - Mustang Evolution
Old 11-23-2013, 10:08 PM   #1
mustangmania91's Avatar
Hi all. What's the easiest way to bleed the front brakes on a '91 GT? I just changed my front rotors & pads and after trying it out afterwards my brake pedal is spongy and brakes are constantly grabbing and holding. Any help would be greatly appreciated
mustangmania91 is offline   Reply With Quote
Old 11-23-2013, 11:25 PM   #2
2300turboford's Avatar
Get a friend to pump the pedal and you bleed em
Old 11-23-2013, 11:35 PM   #3
Should the engine be running? With or without the master cylinder reservoir cap on or off?
Old 11-23-2013, 11:46 PM   #4
jduckz5.0's Avatar
U shouldn't need to bleed brakes after pads n rotor change...did u check your fluid??? Did u clean and grease up the caliper pins???check to see if your brake hoses got linked or twisted...
---------- Post added at 02:46 AM ---------- Previous post was at 02:44 AM ----------
Engine off and cap off...passenger side 1st if your just doing fronts...
jduckz5.0 is offline   Reply With Quote
Old 11-24-2013, 07:14 AM   #5
Mlarv5's Avatar
All this but I would start with the back first passenger side then drivers then front pass and last drivers side. I got one of these and it makes the job really easy to do your self. Also I change my entire brake fluid once ever few years.
Brake Bleeder and Vacuum Pump Kit
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 11-24-2013, 01:39 PM   #6
87LX306's Avatar
Brake fluid starts to retain all of the outdoor moisture in the air the minute you crack open the seal of the bottle. All of that moisture collects in the master cylinder seals, calipers, wheel cylinders, brake hoses as well as abs pumps. A lot of brake failure is due to neglected brake fluid.
Anytime you replace pads/shoes you should crack the bleeders and push the pistons in by hand and allow the contaminated fluid out of that caliper/wheel cyl. Then go ahead and bleed the entire system to rid of all the old fluid. One man bleeder kits can be found at most parts stores for around $10. Remember to only buy enough fluid for that job and scrap the rest.
87LX306 is offline   Reply With Quote
Old 11-24-2013, 02:03 PM   #7
jduckz5.0's Avatar
Come on now...that's overkill...yes I recommend flushing your system but not everytime you need pads n rotors...you sound like you got that out of service manual...my work trucks have never been flushed and my peddle is still just as solid from new in 88 and 93 f150s...
---------- Post added at 05:03 PM ---------- Previous post was at 05:00 PM ----------
Op probably has a collapsing brake hose or a sticky caliper...it became spongy after depressing caliper to replace pads...
Old 11-24-2013, 02:10 PM   #8
87LX306's Avatar
Brake hose collapsing most always is due to moisture from neglected fluid rotting the hose from the inside out.
Old 11-24-2013, 02:58 PM   #9
jduckz5.0's Avatar
True...I'm looking at it as a daily driver situation...I actually agree with you if car isn't used a lot...
Old 11-24-2013, 04:57 PM   #10
I figured it out. I'm embarassed actually. I bought new outter bearings but never even thought about the inner bearings. The new rotors don't come with them. So that was the issue. Thanks for all ur help fellas
05:56 PM
