Polishing - Mustang Evolution
Old 11-26-2013, 06:47 PM   #1
87LX306's Avatar
Polishing
Started knocking down all the rough cast marks on my TFS Heads and polishing them, what do you think?
ID:	138475   Click image for larger version
87LX306 is offline   Reply With Quote
Old 11-26-2013, 07:13 PM   #2
Jinash's Avatar
Nice! I need a set of these for my car
Jinash is offline   Reply With Quote
Old 11-26-2013, 07:30 PM   #3
Looks clean af cool!
KoolPwny is offline   Reply With Quote
Old 11-26-2013, 07:33 PM   #4
Liebert91stang's Avatar
Nice work.looks like they polished up nice
Liebert91stang is offline   Reply With Quote
Old 11-26-2013, 07:40 PM   #5
87LX306's Avatar
Thanks. Takes a little elbow grease, I think it will be worth it.
Old 11-26-2013, 08:04 PM   #6
ALMOST STOCK's Avatar
What method are you using other than sanding?
ALMOST STOCK is offline   Reply With Quote
Old 11-26-2013, 08:11 PM   #7
You going to port them since their out?
Old 11-26-2013, 08:35 PM   #8
87LX306's Avatar
Dremel with a drum bits to take down casting marks. High speed polisher with aluminum polish.
---------- Post added at 10:35 PM ---------- Previous post was at 10:33 PM ----------
Not personally I don't have access to a flow bench so id rather not ruin my heads. Was thinking of dropping them off at fox lake for one of their famous port jobs but we will see.
Old 11-27-2013, 05:01 AM   #9
Might as well while they are out.tf are the best on the market in my opinion.always make great hp
Old 11-27-2013, 01:08 PM   #10
Have you ever tried aluminum polishing compounds rater than aluminum polish?
Old 11-27-2013, 02:41 PM   #11
DustyStang306's Avatar
Ye on my weld rims it works ok but it's no aluminum polish
DustyStang306 is offline   Reply With Quote
Old 11-27-2013, 02:49 PM   #12
87LX306's Avatar
+1
Old 11-27-2013, 02:54 PM   #13
tc x 4's Avatar
If you want it to look like chrome, use sandpaper. Start with 320grit, 600, 1000, 1500, up to 2000grit. If it's fairly smooth skip the 320.
Old 11-27-2013, 02:55 PM   #14
87LX306's Avatar
Old 11-27-2013, 03:01 PM   #15
ColeJohnson's Avatar
Looks great! Good job man.
2016 Comp Orange GT (current)
Old 11-27-2013, 03:50 PM   #16
I'd always had good luck with polishing compounds, actually better than with aluminum polish it seems to bring out a higher shine.
Some of the part I've polished using Emery, Tripoli and White Rouge polishing compounds after I 've sanded the rough casting down.
Old 11-27-2013, 04:07 PM   #17
I'd always had good luck with polishing compounds, actually better than with aluminum polish it seems to bring out a higher shine. Some of the part I've polished using Emery, Tripoli and White Rouge polishing compounds after I 've sanded the rough casting down. ---------- Post added at 02:50 PM ---------- Previous post was at 02:45 PM ---------- Everyone has there own method of polishing but I'm one of those who like less sanding. I start by removing any heavy powder coating (if there is any) with aircraft paint stripper, if the exterior casting is really rough such as the upper intake I’ll start sanding w/ 80 first; but most pieces I’ll start my sanding with 100 grit sandpaper and then move up to 150 or 180 grit and then 220 grit sandpaper. I’ll then move to a Ventilated Flap buffing wheel with Emery compound which does all the work of 320 through 600 grit sandpaper or more, and then I’ll buff with the Tripoli with one Spiral Sewn buffing wheel and polish with White Rouge on a different a Spiral Sewn buffing wheel with an electric drill.
Don't want to hijack this thread, but will that same process work on the 2001 Bullitt's aluminum intake?
Old 11-27-2013, 04:07 PM   #18
87LX306's Avatar
Thanks for the input. Yours looks great
Old 11-27-2013, 04:26 PM   #19
---------- Post added at 03:26 PM ---------- Previous post was at 03:21 PM ----------
Believe me I'm in no way trying to Hi Jack 87LX306 thread either.
To answer your question ... Yes that method works on all aluminum.
Old 11-27-2013, 04:34 PM   #20
What you've done looks fantastic, for me it's just easier working with polishing compounds is all I was trying to say.
Old 11-27-2013, 04:48 PM   #21
87LX306's Avatar
No worries guys. Im going to Lowes next week to grab a few of those wheels. Thanks again for the input.
Old 11-27-2013, 05:16 PM   #22
Yes they look sweet.im jeoulas.hope to have a tf set up next year ; )
10:48 AM
