Driveshaft - Mustang Evolution
Old 11-27-2013, 08:56 PM   #1
fordtough1991's Avatar
Driveshaft
I'm in the process of a 4cyl to a 302 conversion and I bought a yoke to put on the driveshaft that came with the 4cyl but it only slides on the output shaft about 2 inches, is the 4cly driveshaft shorter than a v8 on would be?
fordtough1991 is offline   Reply With Quote
Old 11-28-2013, 08:12 AM   #2
ALMOST STOCK's Avatar
Factory Specs for a 92 which I'll assume holds true for most years.
From the '92 MVMA Specifications:
Numbers are Outer Diameter x Length x Wall Thickness
2.3L 5 speed - 2.75 x 45.50 x .065 - slip yoke, 28 spline, 1330 u-joints
2.3L A4LD - 2.75 x 42.90 x .065 - slip yoke, 25 spline, 1310 u-joints
5.0L 5 speed - 3.00 x 45.30 x .065 - slip yoke 28 spline, 1330 u-joints
5.0L AOD - 3.00 x 45.70 x .065 - slip yoke 28 spline, 1310 u-joints
FRPP M-4602-G - 3.50 x 45.5 x .114 - slip yoke 28 splines, 1330 u-joints
ALMOST STOCK is offline   Reply With Quote
Old 11-28-2013, 08:45 AM   #3
Originally Posted by ALMOST STOCK View Post
Factory Specs for a 92 which I'll assume holds true for most years. From the '92 MVMA Specifications: Numbers are Outer Diameter x Length x Wall Thickness 2.3L 5 speed - 2.75 x 45.50 x .065 - slip yoke, 28 spline, 1330 u-joints 2.3L A4LD - 2.75 x 42.90 x .065 - slip yoke, 25 spline, 1310 u-joints 5.0L 5 speed - 3.00 x 45.30 x .065 - slip yoke 28 spline, 1330 u-joints 5.0L AOD - 3.00 x 45.70 x .065 - slip yoke 28 spline, 1310 u-joints FRPP M-4602-G - 3.50 x 45.5 x .114 - slip yoke 28 splines, 1330 u-joints
Thanks for the info!
10:27 AM
