Blinkers. - Mustang Evolution
Old 11-30-2013, 01:58 PM   #1
5.oh's Avatar
Blinkers.
Was hoping someone on here could help me solve this. I think I found out why my blinkers are not working. This 4 pin connector runs one of the wires the blinkers have and is not connected to anything. Where the hell does this go?!?!?
5.oh is offline   Reply With Quote
Old 11-30-2013, 02:01 PM   #2
5.oh's Avatar
Old 12-01-2013, 04:48 PM   #3
86 muscle's Avatar
What do you mean by not working
86 muscle is offline   Reply With Quote
Old 12-01-2013, 05:59 PM   #4
5.oh's Avatar
When I hit the switch nothing happens. Found out at work today that the yellow/orange wire going into the hazard switch was sitting on my cluster. Still wanna know what that 4 pin goes to though
Old 12-02-2013, 03:32 PM   #5
Roguestang's Avatar
Mine haven't worked in quite a while either. It was my understanding it was a relay in the actual signal arm and it would all have to be replaced. I Figure it happens alot, in almost every car, cause nobody uses thier blinkers anymore anyways.....
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-02-2013, 03:36 PM   #6
86 muscle's Avatar
Stupid questions, have you replaced the flasher? Or the actual switch?
Old 12-02-2013, 03:50 PM   #7
mustangmania91's Avatar
I honestly cld not tell u what that pigtail goes to but, do u know if they worked recently or has it never worked? If it isn't the flasher relay itself ($7) then it very well cld be ur multi-switch. If u buy a Ford OEM replacement ur gonna pay dearly. I changed mine with an aftermarket one from ebay and works like a champ
mustangmania91 is offline   Reply With Quote
Old 12-02-2013, 03:53 PM   #8
Roguestang's Avatar
Ah! The multi-switch is what I was referring to, not the relay. Btw where on ebay and how much was the one you got?
Old 12-02-2013, 04:01 PM   #9
I typed in 1991 ford mustang gt multi function switch. Came right up. $39.95 with free shipping
Old 12-02-2013, 05:28 PM   #10
Roguestang's Avatar
Ok thanks man, I'm gonna try to get one soon.
Old 12-02-2013, 06:06 PM   #11
5.oh's Avatar
Yeah, replaced the flasher and the 15 amp fuse.
---------- Post added at 08:06 PM ---------- Previous post was at 08:05 PM ----------
Rogue stang. Have you checked the yellow/orange wire behind the flasher switch? It kinda integrates with the blinkers so you can't run both at the same time.
Old 12-02-2013, 06:13 PM   #12
Roguestang's Avatar
Naw, I haven't looked at all. Even if I did, I wouldn't have a clue what I was looking at. Electrical work, I usually leave for my mechanic friend to do, unless I absolutely have to.
Old 12-02-2013, 06:19 PM   #13
5.oh's Avatar
What year stanger you got?
Old 12-02-2013, 06:41 PM   #14
Roguestang's Avatar
1990 and 2000
Old 12-02-2013, 11:50 PM   #15
5.oh's Avatar
The '90 will have it. Idk bout the 2000. If you take the two torx screws out the upper part of your dash. Where the cluster is, then there's two bolts by the knee panel. Take those out and then when you get that apart there's a orange and yellow wire that goes into your top right hazard switch. Make sure it's plugged in back there or your blinkers won't work.
Old 12-03-2013, 02:45 PM   #16
Roguestang's Avatar
Next time I get a chance, ill check.
06:39 AM
