Powersteering pump - Mustang Evolution
Old 12-03-2013, 09:47 AM   #1
Varasios's Avatar
Powersteering pump
Pump making horrible noise, thinking im gonna need a new one.
Would you guys recommend a aftermarket/performance one? Or a new OEM one.
Thanks
http://youtu.be/Tsp9yJ0IQkg
Varasios is offline   Reply With Quote
Old 12-03-2013, 10:06 AM   #2
ALMOST STOCK's Avatar
AGR or OEM (OEM also remanufactured) would be my choice for a power steering pump.
The biggest problem with the aftermarket (auto parts stores) power steering pumps I hear about is getting the correct outlet fitting. Seems when the PS units gets rebuilt and reassembled it's a 50/50 chance or less of the correct fitting going on the correct pump.
78-89 ..... SAE fitting
90-97 ..... Metric fitting
ALMOST STOCK is offline   Reply With Quote
Old 12-03-2013, 01:19 PM   #3
Liebert91stang's Avatar
Need to replace mine as well.have heard to replace feed and return lines with new pump also.
Liebert91stang is offline   Reply With Quote
Old 12-03-2013, 02:07 PM   #4
Varasios's Avatar
Yah that sounds like a good idea,
Was checking out the agr on summit..
Seems like a decent unit.
Old 12-03-2013, 03:24 PM   #5
I haven't looked online only at local stores and they have a core charge so you would get some of youroney back but I believe they are rebuilt pumps
Old 12-03-2013, 03:28 PM   #6
Varasios's Avatar
Description: AGR Performance's high performance power steering pumps deliver outstanding power assistance without robbing valuable engine horsepower.
Some features of these pumps include:
* Exterior of casting receives a special finish
* Custom porting to ensure strong fluid flow, while providing a long and cool life
* Interior surfaces and bores are mechanically polished to a fine micron finish
* Specially designed high-temperature, high-rpm seals
* Bearings are custom-sized by a proprietary process for maximum performance at any rpm
* Each pump is 100 percent dyno-checked for pressure, response, and flow at varying rpm
* Each pump receives a stringent fluorescent leak test
Old 12-03-2013, 03:35 PM   #7
How much are they running?i don't think ill do anything too costly being it's just power steering and won't improve hp or fuel
Old 12-03-2013, 03:36 PM   #8
Varasios's Avatar
135 on summit
Old 12-03-2013, 04:23 PM   #9
I believe advance auto wanted $60 and I could get the feed and return line for what that cost all together.i would rather spend more on mods then a pump.but ifs it's shiny it would definitely dress up the looks under the hood
Old 12-03-2013, 05:30 PM   #10
87LX306's Avatar
Never had a problem with a Cardone Reman unit.
87LX306 is offline   Reply With Quote
Old 12-03-2013, 05:32 PM   #11
Never heard of them.is that made in the us?
Old 12-03-2013, 05:41 PM   #12
87LX306's Avatar
Not too sure to be honest. Have you checked RockAuto?
Old 12-03-2013, 06:02 PM   #13
No I haven't.just ordered my fuel system,fuel pump,regulator,gauge and few odds and ends.i don't drive it during winter so the projects will begin ; ) and will put a pump on it this winter as well.
Old 12-03-2013, 08:12 PM   #14
mustangmania91's Avatar
Take my sdvice and go with an AGR pump. I've heard nothing but great reviews from it. I changed mine with a rebuilt pump from Advanced Auto and it whines like u wldnt believe
mustangmania91 is offline   Reply With Quote
Old 12-04-2013, 12:15 AM   #15
87LX306's Avatar
Did you flush the ENTIRE system? Install an inline filter? Put NEW fluid in the ENTIRE system?. Same style pump on my ranger thats on the mustang. Ive used TONS of parts store pumps on ford trucks/suvs/cars over the years.. Yeah maybe one or two made noise months down the road, however the big majority of them work just like factory. Most parts stores offer Lifetime Warranty on these parts anyways, so if in 2 years it starts to get a little noisy wrench it off and swap her out.
Old 12-04-2013, 12:42 AM   #16
87LX306's Avatar
Old 12-04-2013, 04:39 AM   #17
I did flush my system. Did not put an inline filter on. But did use the correct fluid. However, 99% of the people on here all said its a normal and common issue with these yrs mustangs. However, I'm down with trying the 3F's if it makes the noise go away.
Old 12-04-2013, 06:56 AM   #18
Rockauto, get whichever one is cheapest IMO. Or just convert to manual steering with a quick ratio rack and a MM/Flaming river shaft. Frees up weight and its not as hard to turn the front wheels as you think espeically if you do a bunch of weight reduction off the nose and run stock width tires in the front.
Lol, I doubt you're going to want to do that. Again, rockauto, get the best deal, should be G2G.
Old 12-04-2013, 06:05 PM   #19
Varasios's Avatar
Sounds good,
Just wanna replace with something decent so it holds up hopefully
Old 12-05-2013, 02:04 PM   #20
89BossGT's Avatar
I recently installed a new AGR pump on my 89 GT. I followed the bleeding instructions that came with the the pump and it works great. I would definitely recommend it.
89BossGT is offline   Reply With Quote
Old 12-05-2013, 03:28 PM   #21
Hey 89bossGT, was your previous pump really noisy especially when turning the wheel? That's what mine does.
Old 12-05-2013, 04:31 PM   #22
89BossGT's Avatar
No it wasn't noisy. Fluid was leaking out the front seal. I researched about replacing the seal and decided that replacing the entire pump would be the better option. The original pump served me faithfully for 136,000 miles.
Old 12-05-2013, 07:44 PM   #23
Sgt_Syke's Avatar
I did mine with a remanned cardone from local auto parts store. It works fine...had to add more fluid after about a week of driving it, that took care of squealing, since then nothing, works great, it's been on the car now for a year. Follow bleeding instructions.
Sgt_Syke is offline   Reply With Quote
Old 12-05-2013, 08:52 PM   #24
Cool. Makes me wander if I buy a new one again if it will cease the squealing. Drives me nuts
09:45 AM
