Problem still. - Mustang Evolution
Old 12-03-2013, 05:41 PM   #1
5.oh's Avatar
Problem still.
I I adjusted my tps sensor, timing to 12 degrees, and my maf. My car was running great, no surging or sputtering when getting on it. This morning whent to start my car and bam!! It started doing its problems all over again. Left school today and had the heat on and I noticed that it wasn't surging or sputtering no more at that point. Could this be a possible vacumm leak I need to look for tomorrow??
5.oh is offline   Reply With Quote
Old 12-03-2013, 06:19 PM   #2
Liebert91stang's Avatar
Usually your heat won't be good with a vacuum leak.did you check egr valve?you can take carb cleaner and spray around vacuum lines and if the idle changes you found a leak
Liebert91stang is offline   Reply With Quote
Old 12-03-2013, 07:53 PM   #3
SamChildress's Avatar
I have a 85 cfi and mine was doin the same I replaced the same stuff that ur doin and come to find out it was my o2sensor wires were melting on the exhaust
SamChildress is offline   Reply With Quote
Old 12-03-2013, 07:56 PM   #4
5.oh's Avatar
Thanks sam and liebert. I'll do that in a couple mins when I park and see what's going on.
Old 12-03-2013, 08:22 PM   #5
5.oh's Avatar
Pretty sure it's just the whole egr. When I floor it the egr doesn't back off. The bubble thing on the inside.. Doesn't move at all.
Old 12-03-2013, 08:57 PM   #6
I took the egr off and made a plate to block it
Old 12-03-2013, 09:47 PM   #7
5.oh's Avatar
Will that mess with it? Like the fuel ratio, I just have a problem with my car sputtering bad when I floor it
Old 12-03-2013, 10:00 PM   #8
I've had mine like tgat all summer seems to b fine. Mine would load up wit fuel around 2800 rpm then I would floor it then would b good for a few min then repeat.
Old 12-03-2013, 10:23 PM   #9
5.oh's Avatar
Okay kool. Thanks a lot man, I might do a vacumm test tomorrow on it and see what it does. It only closed when I un hooked a line from the passenger side tree and it killed my engine. I'm totally clueless as to what's causing this sputtering
Old 12-03-2013, 10:29 PM   #10
I felt the same way I did sensor all that came out to b o2 sensor
Old 12-04-2013, 09:25 AM   #11
5.oh's Avatar
Did yours pop a code?
Old 12-04-2013, 03:51 PM   #12
tyler k's Avatar
That is exactly what my car is doing. Are you saying the egr was the issue and all you had to do was block it off?
tyler k is offline   Reply With Quote
Old 12-05-2013, 02:17 AM   #13
When I first got it last yea it did open spout circuit fixed that still ran bad o2 never popped up
---------- Post added at 03:17 AM ---------- Previous post was at 03:14 AM ----------
No I blocked that off thinking it was may be that but it wasn't. Come to find out it was the 3wires that plug into the o2 melted on exhaust
Old 12-05-2013, 07:57 AM   #14
You should be able to shake the egr and hear something rattle inside.if not it's stuck.the 02 sensor will bring the check engine light on.gasmilage will decrease and rough idle are symptoms of bad sensors
Old 12-05-2013, 03:56 PM   #15
5.oh's Avatar
Well nothing rattled when I took it off. So I'm guessing I'll start there, then the iac and then the stock fpr
---------- Post added at 05:56 PM ---------- Previous post was at 05:56 PM ----------
Meant a new stock fuel pressure regulator. Even though I change the fuel filter and it was still clean..
Old 02-04-2014, 04:54 PM   #16
5.oh's Avatar
Found out it was my plug wires, and the street burner TFI negative wire was loose so It ended up burning the top of my coil and the middle of the cap on the dizzy. Cleaned with wire brush and brake clean and it's perfectly fine ) thanks for all the help people
12:16 PM
