NEED HELP PLZ - Mustang Evolution
Old 12-06-2013, 04:55 PM   #1
Foxbody91's Avatar
NEED HELP PLZ
Just bought my second fox body I've had it for about 7 months now just replaced alternator. Car won't turn over and it just happened after a friend of mine and I are looking at the carburetor and I noticed it needed to be cleaned. My friend kind of flipped the choke valve open he said it was kind of stuck. Few min later I try to crank my car but it won't turn over. Almost sounds like fuel isn't quite making it to the engine. It fired up twice but cut off few seconds later. It needs a 650 CFM carburetor on it but I've left this one on this whole time and no problems til now. The car has engine bored 30 over its been running fine jus a lil overheating in the summer. Idk wat kind of carburetor is currently on right now I haven't been able to get in touch with the guy I bought it from but it is Holley brand and looks fairly new! Do I go ahead and replace it now or is there something I can do that can hold me over til after Christmas???
Foxbody91 is offline   Reply With Quote
Old 12-06-2013, 08:52 PM   #2
3stangs's Avatar
The numbers on the choke horn will be able to tell you what carb it is. Try spraying starting fluid and see if it starts. That'll eliminate a no fuel start.
3stangs is offline   Reply With Quote
Old 12-07-2013, 12:21 AM   #3
Foxbody91's Avatar
Ok ill try that tomorrow once I get off work
Old 12-07-2013, 01:03 AM   #4
Tyoung68's Avatar
It sounds like he pulled the choke off were you trying to pump the gas while cranking it?
Old 12-07-2013, 06:31 AM   #5
3stangs's Avatar
If he pulled the choke off then he needs a new car cause that one is a pos. Lol.
Edit:carb not car.
Old 12-07-2013, 08:47 AM   #6
Foxbody91's Avatar
Yes but I always tap the gas a bit when I crank the car
Old 12-07-2013, 08:52 AM   #7
3stangs's Avatar
After reading it again I have to ask. Does it have fuel in the tank?
Old 12-07-2013, 10:31 AM   #8
Liebert91stang's Avatar
Holly carbs can be tempermental and have to be adjusted when the weather changes
Liebert91stang is offline   Reply With Quote
Old 12-07-2013, 12:57 PM   #9
Foxbody91's Avatar
I fixed it this morning thanks for the help the choke was stuck closed I cleaned it and it works just fine now. I guess one of those simple fixes right in front of your face that you overlook
---------- Post added at 02:57 PM ---------- Previous post was at 02:55 PM ----------
Trying to start the car I couldn't see if it was opening and closing properly so finally my gf gave me the extra set of eyes
Old 12-07-2013, 02:06 PM   #10
I would tell everyone you gf fixed it for you.haha jk
Old 12-07-2013, 07:28 PM   #11
Foxbody91's Avatar
Lmao
11:28 PM
