Temperature problem. - Mustang Evolution
Old 12-06-2013, 07:26 PM   #1
Polo_FiveOh's Avatar
Hey Guys.
Recently my fox started over heating. So long story short I changed the water pump. Thermostat. And the temperature sensor. The car starts to heat up when the heater is off. But when it's on it maintains its regular temp. And when giving a couple of light acceleration the coolant in the reservoir started bubbling and rising.. Could it be the radiator itself ?
Polo_FiveOh is offline   Reply With Quote
Old 12-06-2013, 07:32 PM   #2
mike_jay5.0's Avatar
Air in the system possibly
mike_jay5.0 is offline   Reply With Quote
Old 12-06-2013, 07:44 PM   #3
What do you mean by that ?
Old 12-06-2013, 07:55 PM   #4
Thermostat is bad. Pick up a new one and drill two 1/4 holes 180° apart. Reinstall.
Old 12-06-2013, 08:08 PM   #5
How could that change anything ?
Old 12-06-2013, 08:11 PM   #6
ALMOST STOCK's Avatar
When was the last time the coolant system use flush out?
ALMOST STOCK is offline   Reply With Quote
Old 12-06-2013, 08:19 PM   #7
Before I put the water pump. It was fully drained. After I put the water pump. Put the coolant in.
Old 12-06-2013, 08:33 PM   #8
It allows some coolant to pass through even if thermostat sticks closed.
You are either low on coolant or thermostat is stuck.
Old 12-06-2013, 08:42 PM   #9
So you haven't flushed your system then.. you just drained it is all.
Old 12-07-2013, 05:39 AM   #10
mustangmania91's Avatar
Off the top of my head, if u have air trapped in ur system, ur temp a lot of times will rise extremely high, then suddenly drop out. Also, a flush is recommended
mustangmania91 is offline   Reply With Quote
Old 12-08-2013, 01:40 AM   #11
Aight guys. Goes to show my heater hose had a tiny hole. Changed it so now it not over heating. Problem now is that the heater itself isn't heating up that much. So should I go on with the coolant flush ?
Old 12-08-2013, 06:06 AM   #12
Foxbody91's Avatar
Always better to be safe than sorry..may prevent problems later
Foxbody91 is offline   Reply With Quote
Old 12-08-2013, 07:21 AM   #13
Thanks man. And thanks to everyone else. You guys are always helpful.
10:27 AM
