Fuel Pump? - Mustang Evolution
Old 12-17-2013, 09:00 AM   #1
Fuel Pump?
91 notch won't start, battery has more than enough amps to start and the alternator is new so the only other thing I can think of is the fuel pump. Any thoughts?
91NotchPhil is offline   Reply With Quote
Old 12-17-2013, 09:22 AM   #2
Car needs 3 things to run. Air, spark, fuel. Have to checked for power at the plugs? Fuel at the rail?
Old 12-17-2013, 01:42 PM   #3
Roguestang's Avatar
+ infinity
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-18-2013, 10:26 AM   #4
Foxbody91's Avatar
Does it start then cut off? Not turning over? Any particular sounds??
Foxbody91 is offline   Reply With Quote
Old 12-18-2013, 06:53 PM   #5
5.oh's Avatar
Do a couple shots in the throttle body with starting fluid. If it fires up and dyes it's your fuel pump. Take two plugs next to each other off the distributor and turn it over see if it's atleast getting spark.
---------- Post added at 08:53 PM ---------- Previous post was at 08:51 PM ----------
Btw for the spark thing it'll when you turn it over have someone else looking and see if there's any electric arking.
5.oh is offline   Reply With Quote
Old 12-27-2013, 05:48 AM   #6
Mike93coupe's Avatar
Had same problem with my 93 coupe. I replaced the TFI module and the coil..
Mike93coupe is offline   Reply With Quote
04:24 PM
