3.73 gears 1990 gt - Mustang Evolution
Old 12-20-2013, 10:53 PM   #1
1990's Avatar
3.73 gears 1990 gt
I am picking up my mustang tomorrow. Got 3.73 gears and a bearing kit installed. Is there a certain time frame I should let the gears get "broken in" ? Or should it be good to go when I pick it up?
1990 is offline   Reply With Quote
Old 12-20-2013, 11:20 PM   #2
foxbox's Avatar
If they were properly installed there should not be any ”break in” period.
foxbox is offline   Reply With Quote
Old 12-21-2013, 12:04 PM   #3
Liebert91stang's Avatar
There shouldn't be a break in process and be prepared for a huge difference.you will be happy with the results
Liebert91stang is offline   Reply With Quote
Old 12-21-2013, 02:17 PM   #4
1990's Avatar
I am very happy with the results
Old 12-21-2013, 02:28 PM   #5
That will probably be the beginning of a modification process.you may become addicted to mods
Old 12-21-2013, 02:44 PM   #6
Roguestang's Avatar
Sweet! Do you have an AOD or T5?
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-21-2013, 02:48 PM   #7
foxbox's Avatar
this makes me want 3.73s even more lol
Old 12-22-2013, 09:47 AM   #8
1990's Avatar
AOD
Old 12-22-2013, 09:59 AM   #9
Roguestang's Avatar
AOD
Nice! I swapped out the aod for a t5 in my Fox. I bet those 3.73's really make a difference. If you don't already, I'd look at a higher stall converter too. I've still got the TCI streetfighter converter I had in the car before I swapped for a manual. And it made a difference (and I still had 2.73's)
Old 12-22-2013, 10:14 AM   #10
Yes roguestang is on it.I have a 2800 stall and it complements the gears.will put you back in your seat as you launch it.would be a nice addition to the gears
Old 12-22-2013, 11:00 PM   #11
4.10's are the best thing i've done to my aod 90. Not correcting the speedo, not so much.
Old 12-23-2013, 08:59 AM   #12
I forget but aren't the drive gears actually part of the output shaft on the AODs or is it still 7 or 8 tooth plastic gear? I know on the manuals its plastic.
Crappy thing about the foxes is its a mechanical speedo so you can't use a speedcal and there is no gear to correct for anything higher than 3.27 with the 8 tooth drive gear and 3.73 with the 7 tooth.
Old 12-23-2013, 10:10 AM   #13
Honestly i've never looked into it that hard. I just know 95mph on the speedo is around 72.
01:30 PM
