Adjustable gas pressure regulator - Mustang Evolution
Old 12-28-2013, 08:29 PM   #1
Liebert91stang's Avatar
Just want to say whoever designed the location of the regulator on 91 wasn't the one changing it out.having problems getting bolt in back below fuel rail.anyone know a tool that will help?the bolts are Alan head and make it tough to start with an Alan key
Liebert91stang is offline   Reply With Quote
Old 12-28-2013, 08:45 PM   #2
5.oh's Avatar
I know for some half inch ratchets they make Alan sockets that are no bigger then the short side of an Alan key.. Might wanna browse around at an oriellys or tool store.
5.oh is offline   Reply With Quote
Old 12-28-2013, 09:16 PM   #3
That's what I was thinking.i have some but they are too long.have to go to parts store tom and get few things and going to see if they have something that will help.
Old 12-29-2013, 12:19 AM   #4
The right tool makes all the difference. Allen head sockets and an extension and you'll go right in. Also its called an "Adjustable Fuel Pressure Regulator" or "AFPR". Kirban has been the best one I've used. Hopefully you do not have a BBK or a generic one...
Old 12-29-2013, 03:32 AM   #5
5.oh's Avatar
True dat Scottie! Learned that quickly being a mechanic.. Gotta spend money to make money.
Old 12-29-2013, 08:17 AM   #6
I'll get the right tool today and it is a kirban regulator
Old 12-29-2013, 02:42 PM   #7
Good deal, Kirban is the best. BBKs leak, even Aeromotives have issues...
Old 12-31-2013, 12:34 PM   #8
M3no956's Avatar
I've got a bbk and doesn't leak
M3no956 is offline   Reply With Quote
Old 12-31-2013, 02:59 PM   #9
I had a BBK leak all over the damn place. After some research, turns out its common. If you got a good one consider yourself lucky and roll with it.
Old 01-01-2014, 08:45 AM   #10
M3no956's Avatar
Well guess I'm lucky, what should the fuel pressure be at?
Old 01-01-2014, 08:55 AM   #11
Stock motor is 43
Old 01-01-2014, 10:36 AM   #12
Around 40 psi vac off. That's right around stock.
Old 01-01-2014, 06:38 PM   #13
hondarocks61's Avatar
You may also be able to cut down a spare allen key to fit in the small space as well.
hondarocks61 is offline   Reply With Quote
03:00 AM
