Only one reverse light works - Mustang Evolution
Old 12-29-2013, 10:36 AM   #1
91MustangNSB's Avatar
So I replaced both of my bulbs and now only the driver side reverse light works I'm thinking maybe I didn't screw it in tight enough on the passenger side. I pulled the fuse and plugged it back in with no luck. Any other suggestions thanks.
91MustangNSB is offline   Reply With Quote
Old 12-29-2013, 10:42 AM   #2
TorchRed6's Avatar
you might have put it in the wrong way. or just got a bad bulb
TorchRed6 is offline   Reply With Quote
Old 12-29-2013, 12:45 PM   #3
ALMOST STOCK's Avatar
You say that you replaced both backup bulbs, do you know if they were both working before you replace them?
Have you check to make sure when you removed the connector from the tail light housing that you didn't release a wire from inside the connector?
Is the a bulge in the wiring that could indicate a broken wire or where it has been heated and no longer making contact with the rest of the wire?
ALMOST STOCK is offline   Reply With Quote
Old 12-29-2013, 02:18 PM   #4
Thanks for the tips I'm going to be home tomorrow I'm out of state right now I'll check all those things then get back on here
03:19 PM
