Removing hose from oil fill to throttlebody - Mustang Evolution
Old 12-29-2013, 10:53 AM   #1
Liebert91stang's Avatar
I notice there is more than usual oil residue inside the intake.i know the pcv valves on mustang aren't worth a **** but was wanting some feedback on eliminating the hose from oil fill to throttlebody.anyone have some input?
Liebert91stang is offline   Reply With Quote
Old 12-29-2013, 01:20 PM   #2
Roguestang's Avatar
You could always put an oil filter catch can on. Or even filter breather cap(s). But that really just gonna help with crank case pressure.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-29-2013, 05:12 PM   #3
Sgt_Syke's Avatar
+1, how much oil, there should be some in there. Why do you feel there is too much? Breathers are the only way to remove that hose.
Sgt_Syke is offline   Reply With Quote
Old 12-29-2013, 05:20 PM   #4
I think that the pcv valve would take the crankcase pressure and be fine if I capped off the hose.the hose was full of oil build up and I think that would eliminate some of the oil getting into the intake
Old 12-29-2013, 05:26 PM   #5
Roguestang's Avatar
There's always gonna be some oil in the intake. If there is more than usual, you may have a bigger problem, and removing that hose isn't going to fix an underlying issue.
Old 12-29-2013, 06:06 PM   #6
I don't think it's rings or seals because it doesn't ever smoke.i was just trying to eliminate some of the oil blow by.it shouldn't hut it but if I need to leave it then I guess that just what need to be
Old 12-29-2013, 06:50 PM   #7
Roguestang's Avatar
Gotcha. Then the best way is an oil catch can.
Old 12-29-2013, 06:53 PM   #8
ALMOST STOCK's Avatar
Have you ever changed the PCV filter/ not the PCV valve but the actual PCV filter?
ALMOST STOCK is offline   Reply With Quote
Old 12-29-2013, 07:20 PM   #9
No but I got pcv valve and going to pull out screen and clean it
Old 12-29-2013, 07:25 PM   #10
You can clean the PCV screen no doubt but it seems for all the trouble and everything I've read over the years you're actually better off replacing the PCV screen.
Old 12-29-2013, 07:29 PM   #11
Roguestang's Avatar
+1
And they're cheap enough too
Old 12-29-2013, 10:10 PM   #12
Sgt_Syke's Avatar
+2
09:43 PM
