400 hp With a stock cam - Mustang Evolution
Old 01-04-2014, 11:14 AM   #1
white95mustang's Avatar
400 HP 302 ci AFR 165 cc(Stock Cam)
i stumbled upon this article about 2 days ago, and i was highly intrigued by it. The only thing i'm wondering is considering this ad is from july 2003, would it still apply to todays products that are being produced?
I have been trying to look for a N/A 350+ horse power build for under 3grand and this looks the most promising.
if all of this is true, would i lose any power keeping the car fuel injected, or would switching to carbureted make that much of a difference?
white95mustang is offline   Reply With Quote
Old 01-04-2014, 06:58 PM   #2
Sgt_Syke's Avatar
Switching it won't make enough of a difference to matter. Those don't really change your power numbers.
Sgt_Syke is offline   Reply With Quote
Old 01-04-2014, 10:36 PM   #3
you're talking about the carbureted vs efi difference, correct?
Old 01-04-2014, 11:27 PM   #4
I see no reason not to believe that Car Craft article. Good flowing intake, heads, and a nice set of headers go a long way. Your stock intake probably won't flow like the Weiand/Demon set-up that they used but I doubt you'd see a dramatic drop in the numbers.
Old 01-04-2014, 11:52 PM   #5
and i can always get a bigger / better flowing intake manifold.
Old 01-04-2014, 11:55 PM   #6
TheRoadWarrior's Avatar
EFI is going to be more efficient, reliable and keep tuning capabilities ie Bama, Quarterhorse etc on the table, which can really make a big difference on a 400hp motor.
1995 GT. HCI 3500stall 4.10 gears.
1986 SVO project.
TheRoadWarrior is offline   Reply With Quote
Old 01-05-2014, 01:56 PM   #7
Sgt_Syke's Avatar
Correct, I was referring to efi v. Carb, no diff really.
Old 01-05-2014, 07:07 PM   #8
also 1 more question i forgot to ask, will the tri-y headers fit into a mustang? only because it said it was the motor was being put into a 60-65 falcon
Old 01-05-2014, 08:49 PM   #9
Unfortunately, I don't think that Doug's makes.a long tube header for your car. You could call them and make sure though.
You should be able to achieve similar results with any QUALITY long tube header though.
Old 01-06-2014, 05:17 PM   #10
A stock headed AFR165 stock cam and good intake with bolt on/tune combo is good for around 280-300rwhp and that's about the limit of it, at least before a power adder. Word of advice, don't believe anything the magazines print. They inflate their numbers and make wild claims to sell magazines and get advertisers to pay them for space.
Old 01-06-2014, 07:11 PM   #11
Awww, they're not that far off Scotty. Those numbers were on an engine dyno without all of the in car restrictions of the vehicle. With the drivetrain loss the numbers are close...
Kinda.
Old 01-06-2014, 11:00 PM   #12
You guys made me feel a little better on my GT40P setup rather than what I was originally saving for which was the AFR 165. I had saved 1,500$ and was gonna dump it on the AFR heads, but instead pulled together my whole salvage yard combo for the same money, maybe a little less.
1986 SVO project.
Old 01-07-2014, 12:52 PM   #13
well my goal is atleast ~320 wheel power. In the magazine print, they said theyre refering to power at the fly wheel, which is obvious. i dont plan on making any where near 400 wheel with this set up, you have to take into account of the loss of power between the motor and the wheels it self which is near roughly a 15% difference
Old 01-07-2014, 01:29 PM   #14
That isn't a 400 fwhp set up either. Those setups dyno at 280ish usually with the stock cam. If you factor in 15% driveline loss that's around 330fwhp. Again, the rags purposely inflate numbers and print flat out lies sometimes to sell product or just get ppl to read (and therefore get paid from advertisers).
You want a good combo? Do a GT40 head/intake/stock cam and supercharge it. 425-450whp, stock gas mileage, stock street manners, completely emissions legal no spending $2500-$3000 on a HCI and making 100hp less than someone with the supercharger. I learned this the hard way.
Old 01-07-2014, 04:40 PM   #15
Well, will you at least agree that you could have a pretty solid 350 bhp engine using that combination?
Just so that we don't have to go back and forth about how driveline losses can vary, a good deal, from that 15% that I see tossed around all of the time..
Old 01-07-2014, 04:55 PM   #16
mike_jay5.0's Avatar
That build only produced mid 300hp. I have heard that the dyno they used was not calibrated.
mike_jay5.0 is offline   Reply With Quote
Old 01-07-2014, 05:17 PM   #17
15% is the give or take parasitic loss, it could be more, it could be less, rwhp numbers are also tossed around too much vs timeslips.
Old 01-07-2014, 05:33 PM   #18
Yep. Dyno numbers are good for measuring gains/losses during tuning and that's about it IMO...
12:14 PM
