Idling issue? - Mustang Evolution
Old 01-05-2014, 09:44 PM   #1
antnvlz1294's Avatar
Question Idling issue?
I posted a video below, although what the main issue is( if you cant notice in the video) the rpm keeps bouncing as you can see, and it seems to only do this at night when I have my headlights on. Also if you look toward the end of the video, while the rpms are "bouncing" the battery indicator gauge is moving up and down a tiny bit. Ive replaced the stock alternator with a 130 amp 3g. The car is stock but i am receiving no codes... also the car sometimes misfires when the headlights are on usually when im going from 4th to 5th around 45mph, 2-3000 rpm.
thanks!
antnvlz1294 is offline   Reply With Quote
Old 01-06-2014, 06:20 AM   #2
Liebert91stang's Avatar
Did you replace the wire with bigger when you replace the altanator?
Liebert91stang is offline   Reply With Quote
Old 01-06-2014, 08:07 AM   #3
Yes i did I bought the bigger power wire that goes from the alternator the the ignition module.
Old 01-06-2014, 08:19 AM   #4
Good also recommend doing the negative from battery as well.the surpintine belt could be slipping causing idle issues.if the tension pully is plastic I would go steel.
Old 01-06-2014, 08:21 AM   #5
Yeah the pully is plastic, it kind of looks like the belt moves slow.. And what do you mean a negative to the battery?
Old 01-06-2014, 08:29 AM   #6
mystang50's Avatar
he means replace/rewire the negative wire to
Old 01-06-2014, 08:29 AM   #7
You need to install a ground between negative to fender in 4wire as well
Old 01-06-2014, 08:31 AM   #8
Oh okay! I gotcha! I'll have to get on that.
---------- Post added at 09:31 AM ---------- Previous post was at 09:30 AM ----------
I believers already is one installed
---------- Post added at 09:31 AM ---------- Previous post was at 09:31 AM ----------
Believe theres*
Old 01-06-2014, 08:36 AM   #9
There should be one installed just need to make sure it's big enough.4 wire
Old 01-06-2014, 08:37 AM   #10
Mots really small so I doubt it is a 4 wire...
Old 01-06-2014, 08:38 AM   #11
Sgt_Syke's Avatar
Sounds like current draw to me. Does idle bounce any other time? If not its got to be the lights...something in the wiring is not right.
Sgt_Syke is offline   Reply With Quote
Old 01-06-2014, 08:40 AM   #12
Sgt_Syke's Avatar
Nvmnd.
Old 01-06-2014, 08:40 AM   #13
It only bounces with the headlights on.
09:57 PM
