Trickflow street burner Or Cobra intake on street 5.0 ? - Mustang Evolution
Old 01-08-2014, 01:04 PM   #1
I am trying to decide on either the trick flow street burner upper and lower or cobra intake for my 5.0 rebuild? Witch one will work better for my set up? It's gonna have
Rebuilt block .30 over
New pistons
70mm throttle body
Bbk Mas air flow censor
24lb injectors
Bbk under drive pullies
Ford racing lifters
Comp double roller timing chain
b303 cam
Gt40p heads
Crane 1.7 rr
Comp springs
Msd distributer
Msd ignition box
255 lph fuel pump
robq5oh is offline   Reply With Quote
Old 01-09-2014, 06:56 AM   #2
The Cobra, there would be no benefit and a bottom end loss going with the TFS intake. Also if your stock lifters are fine there is no reason to get new ones. I'd also advise agaisnt the BBK MAF, go with another brand, stick with a stock distributor over MSD crap and also 0 reason for an ignition box with this combo (will save you some $$).
Going to want some hardened 1 piece pushrods too, will need to measure to get the proper length. Everything else looks good. Motor should make a solid 275 to the wheels through a 5 spd.
Old 01-11-2014, 09:17 PM   #3
TheRoadWarrior's Avatar
^ great advice! Wish more were as conservative with advice on mods as scotty here. I been telling more and more people to just get explorer intake or cobra, they support almost 350hp without sacrificing anything! (ported lower of course)
1995 GT. HCI 3500stall 4.10 gears.
1986 SVO project.
TheRoadWarrior is offline   Reply With Quote
10:40 PM
