Straight pipes? - Mustang Evolution
Old 01-10-2014, 04:00 AM   #1
Cblowe13's Avatar
Straight pipes?
It's got a four eyed 83 gt and she ain't purty. But pretty dang quick. Has an exhaust leak at the moment. I love the sound of straight pipes. I have a set of shorty headers and was wondering of anyone had this set up? I like the crispy growl. Lol
Cblowe13 is offline   Reply With Quote
Old 01-11-2014, 02:03 PM   #2
TheRoadWarrior's Avatar
I wouldn't, losing back pressure all together loses low end power, and that's where majority of folks get their kicks! The top end gains to be had from straight pipes are too far up in the powerband of a street car to be useful unless you are driving it wide open throttle all day. my 0.2cents
1995 GT. HCI 3500stall 4.10 gears.
1986 SVO project.
TheRoadWarrior is offline   Reply With Quote
Old 01-11-2014, 02:12 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
Back pressure is a myth
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 01-11-2014, 02:33 PM   #4
UltArc's Avatar
Back pressure is a myth, but low end power losses can occur- usually not much. I don't fully recall exactly how it works, but not having the consistant flow does influence it. As long as emissions don't matter, shouldn't be an issue.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 01-11-2014, 02:36 PM   #5
Butch's Avatar
Region: New Mexico
4:10's or higher will take care of this "lost low end" ;ΒΆ
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 01-11-2014, 04:45 PM   #6
ALMOST STOCK's Avatar
BACH PRESSURE... myth or fact
Back pressure is a very misunderstood entity. The assumption is that larger pipes = lower back pressure and smaller ones = more back pressure. That is a simplistic view of things... but it is within that paradigm that the idea of "back pressure for torque, free flow for top end power" emerges.
It is not accurate.
At any given RPM, what is desired is the maximum flow. You want the gases to be moving out of the cylinders, through the exhaust system, and out the tailpipe as efficiently as possible. According to Bernoulli's law, we know that as pressure increases, flow decreases, and as flow increases, pressure decreases. So we want the lowest possible back pressure at any given RPM.
If you want an engine with stump-pulling torque, with peak power at 2000 RPM, you want an exhaust system that provides the least possible back pressure at 2000 RPM. Such an exhaust system is necessarily going to be smaller in diameter than one which is tuned for maximum power at 5000 RPM on an engine of the same displacement. That smaller diameter does not mean it "has" more back pressure than a wider diameter one! Back pressure is not a static measurement of a given exhaust system like tube diameter or wall thickness. It varies with RPM and engine load, and a tube that provides the least back pressure and the most flow at one RPM won't have the least back pressure or flow at other RPMs.
So, the exhaust that gives the stump-pulling torque has LESS back pressure than the wider diameter exhaust at low RPM. In the larger exhaust at low RPM, there is flow stagnation and turbulence, and the result is that there is more resistance to flow (back pressure) than the smaller exhaust... at that RPM.
Rev the engine toward the red line and the back pressure inside the small-diameter tube will increase, and flow will be restricted. However, in the wider tube, the previously stagnant flow will increase and become more laminar, and the back pressure will decrease.
So each of the two exhausts above has the least back pressure within the RPM range for which it is designed. "Back pressure" as a single number simply does not tell which exhaust is most suitable for any given application. It's all about flow... pressure is secondary to that. If you think in terms of matching the exhaust flow to the flow potential to the rest of the components in the engine, the confusion over back pressure becomes irrelevant.
So, go for the exhaust system that has its peak flow potential in the RPM range desired. If your engine is built for torque, you would want a smaller exhaust system; a revver will want a bigger one.
Also, flow stagnation sounds like drone! Many times you will hear about someone who had too wide an exhaust on his car, and it boomed like there was no tomorrow. Put in a narrower, more appropriate exhaust for the RPM (and displacement... talking NA vehicles here, as power adders act like bigger engines in terms of exhaust flow), and it quiets down noticeably. I had that happen with my Ford Ranger when the exhaust guy inexplicably decided to custom build me a 3" cat back on my 2.9 when I had asked for the Dynomax cat back. The noise was horrendous, and the low end was gone. I went back and got what I had actually wanted, and the bottom end was back, and it was near silent-- drone free, with the same type of muffler (Super Turbo).
Read this also.
http://www.veryuseful.com/mustang/te...Scavenging.pdf
Note this bit from the link above --
"However, Wollongong (Australia) mechanic Kevin Davis has done extensive testing of varying backpressure on a number of performance engines. These range from turbocharged Subaru Legacy RS flat fours to full-house traditional pushrod V8s. In not one case has he found any improvement in any engine performance parameter with increased exhaust backpressure."
A lot of folks interpret that result to mean that larger is better. Not so. You want the smallest system you can have that will still handle the peak exhaust flows with minimal back pressure. Going larger than you need to can have detrimental effects on bottom end torque without helping you any up top. Because it can hurt system velocities and interfere with effective scavenging.
ALMOST STOCK is offline   Reply With Quote
Old 01-11-2014, 08:27 PM   #7
"A lot of folks interpret that result to mean that larger is better. Not so. You want the smallest system you can have that will still handle the peak exhaust flows with minimal back pressure. Going larger than you need to can have detrimental effects on bottom end torque without helping you any up top. Because it can hurt system velocities and interfere with effective scavenging."
This makes sense. Thanks!
1986 SVO project.
Straight pipes? Yes or no? thatmustangguy 2005-2010 Mustang GT 11 05-31-2012 04:40 AM
99-04 Straight pipes GP3GT 1996-2004 Mustang GT 10 01-29-2012 12:54 AM
straight pipes vs x kid_kash_00 1979-1995 Mustang GT 3 12-02-2011 08:26 PM
Straight pipes 96 stang 1996-2004 Mustang GT 23 09-20-2011 11:54 PM
01:47 AM
