I need help - Mustang Evolution
Old 01-11-2014, 12:44 AM   #1
Cblowe13's Avatar
I need help
83 gt 302 just got it yesterday. Was driving around town today after driving it the whole day yesterday. It was cold this morning when I started it but when I left it was sputtering in second. Thought it was just cold but then got to the light turned left and it shut off? Then started back up drive a mile and shut off again. I don't have a clue what it could be. I was told possible fuel pump but the guy told me it was just replaced. Any other ideas if this isn't it, like electrical? Thank you for you're help
Cblowe13 is offline   Reply With Quote
Old 01-11-2014, 07:11 AM   #2
DK Racing's Avatar
I had a problem just after replacing the electric fuel pump in my 87 the harness was bad at the tank. I have the electric one not sure if your model has a mechanical one on the motor?
DK Racing is offline   Reply With Quote
Old 01-11-2014, 07:19 AM   #3
Could be the tfi module. Those things cause it to die when they go out. Let the car cool for 10 minutes and you can get another 10 miles before it shuts down.
Sent from my massive johnson.
Old 01-11-2014, 09:09 AM   #4
ALMOST STOCK's Avatar
When was the last time the fuel filter was changed ?
ALMOST STOCK is offline   Reply With Quote
Old 01-11-2014, 03:56 PM   #5
Cblowe13's Avatar
I had to get it towed. Said the pump was replaced a month ago
Old 01-11-2014, 04:04 PM   #6
Cblowe13's Avatar
How do I find out if it's the mechanical one? It's at the shop now. I'm not very mechanical myself just trying to learn now. And idk i let it cool for two hours and it wouldn't start so idk about the tfi?
---------- Post added at 06:04 PM ---------- Previous post was at 06:02 PM ----------
The guy said a month ago. Idk if it's mechanical or not how do I know? And also I let it cool for two hours still nothing
Old 01-11-2014, 04:09 PM   #7
I was wonder when the last time the fuel FILTER was replaced not the fuel pump.
You had already said before at the starting of your thread
Old 01-11-2014, 09:34 PM   #8
Foxbody91's Avatar
Don't feel bad I'm trying to learn my way around the engine too. Got outta high school and after shop class I kinda got distant with cars instead if keeping up at it. My first mustang did exactly what yours is doing and what it was is my fuel filter was bad and fuel pumps were drowning my engine out. I also made the mistake of taking it to ford to get it fixed. That'll never happen again big no no. Cost me 1300 for the fix. It's alot easier though bro if you ask for advice on here and do the work yourself, alot cheaper also these guys will give u walk through on everything you need to do so if you want to have the shop jus identify the problem and tow it back home it'll save you some $$
Foxbody91 is offline   Reply With Quote
Old 01-11-2014, 11:03 PM   #9
Cblowe13's Avatar
Well that's my problem I don't have a clue where the fuel filter even is or how to fix it. What is the best price you think I could get on a job like this? A local church friend price lol
Old 01-11-2014, 11:23 PM   #10
Foxbody91's Avatar
Rear end it's a small cyliner shaped. You'll need a drain pan too. If u know someone with a lift its easier to. It's almost directly in between the two rear tires ill show you a pic of one
Old 01-11-2014, 11:28 PM   #11
Foxbody91's Avatar
Name:	ImageUploadedByMustang Evolution1389508081.008251.jpg
Old 01-11-2014, 11:29 PM   #12
Foxbody91's Avatar
There's two hoses you'll have to detach and a round bracket you'll have to loosen to pull filter out.
Old 01-11-2014, 11:45 PM   #13
Foxbody91's Avatar
As for the price that depends on ur friend. Professionally it may run u between 130-150. Labor is what will cost you, the part is around $30 or $40 idk for sure
Old 01-12-2014, 02:43 AM   #14
Cblowe13's Avatar
Makes since thanks for the help bro you had anymore probs since you replaced it?
Old 01-12-2014, 03:10 AM   #15
Foxbody91's Avatar
After it was fixed no but that was my first Stang it's R.I.P now
Old 01-12-2014, 03:55 AM   #16
Cblowe13's Avatar
That sucks I got my first fox body. I got a 11 v6 blacked out right now. Waiting on the supercharger cash lol
Old 01-12-2014, 05:13 AM   #17
Foxbody91's Avatar
Nice. Once u get mustang fever it's hard to break. Don't think I could drive anything else. Still deciding on turbocharge or supercharge on my '91. 3.73 gears and 650 CFM carb is on my list next. But good luck on the fuel issue hopefully it helped keep us posted. Got any questions just ask
Old 01-12-2014, 05:37 AM   #18
Cblowe13's Avatar
Either would be fine with me for sure. Will do should be soon I hope
Old 01-12-2014, 06:32 AM   #19
Liebert91stang's Avatar
All you need is a to do is slide under back of car.the filter should be right on other side on gas tank.take a standard screwdriver and there will be a clip on both sides of the filter to hold lines on.tou should be able to get a filter for about $10 at any parts store.its a easy change
Liebert91stang is offline   Reply With Quote
Old 01-13-2014, 05:30 AM   #20
92coupe's Avatar
There should be a filter right on the front of the carb it unscrews and has a screen inside if it
92coupe is offline   Reply With Quote
Old 01-13-2014, 07:43 AM   #21
Cblowe13's Avatar
Okay and the carb is the circular edelbrock On tip right? Don't see what unscrews in front of it
Old 01-13-2014, 08:47 AM   #22
92coupe's Avatar
Yea it's the circular thing on top there should be a line running in the front of it with a brass fitting (I think it's brass?) and a hose connected to the fitting
Name:	ImageUploadedByMustang Evolution1389628006.074040.jpg
Number 3 is the filter if yours is that style
05:50 AM
