how do you change the front main seal on a 1994 302 - Mustang Evolution
Old 01-11-2014, 03:56 PM   #1
94gtconvert's Avatar
I have seen people have to pull the timeing cover but I don't want to. I saw a bronco forum and the guy said you can just take the balancer off and pull the old one out like The rear one. Who's right?
94gtconvert is offline   Reply With Quote
Old 01-11-2014, 04:29 PM   #2
ALMOST STOCK's Avatar
You don't have to remove the timing cover to replace the front seal!
I did it a few weeks ago.
Once the balancer was off I used a pair of Vise grips to grab the flange lip of the seal. I screwed the adjustment on the Vise grips as tight as it could get it and still be able to clamp the jaws shut. I clamped the Vise grips on with the release handle facing the radiator and rocked the backside of the Vise grips against the timing cover. A short prayer for divine intervention and a big tug resulted in the seal prying loose on one side. Some more pressure on the Vise grips resulted in the seal prying loose. Since the balancer had spun and was in two pieces, I used the center part of the old balancer to drive the new seal in place. Coat the seal's metal shell with a little bit of blue silicone for leak protection.
ALMOST STOCK is offline   Reply With Quote
Old 01-11-2014, 08:18 PM   #3
TheRoadWarrior's Avatar
Wow, glad I read this topic, I never thought to do that. Usually I just waited until I had all the other stuff together to do it all at once (chain, cam install, new oil pan gasket etc.) because it was such a pain, now I have a shortcut! Thanks!
1995 GT. HCI 3500stall 4.10 gears.
1986 SVO project.
TheRoadWarrior is offline   Reply With Quote
First time at the track Brad598400 2011-2014 Mustang GT 34 02-04-2013 11:54 PM
Front seal leaking Rob94gt 1979-1995 Mustang GT 17 08-30-2012 08:33 PM
rear main 89 5.0 jacob.a.gasparp 1979-1995 Mustang GT 20 02-18-2012 07:04 AM
front main seal FLAT BLACK GT 1979-1995 Mustang GT 4 01-18-2012 02:12 PM
12:12 PM
