Computer - Mustang Evolution
Old 01-14-2014, 11:16 AM   #1
carlosmorris29's Avatar
Computer
How can I tell if my computer in my 95GT is bad? Is there a way to have it checked?
Sent from my SPH-L710 using Mustang Evolution mobile app
carlosmorris29 is offline   Reply With Quote
Old 01-14-2014, 03:19 PM   #2
Sgt_Syke's Avatar
Why do u suspect the computer is bad? I'm not 100%, but I would think it would throw a code if something was wrong...you could prolly have it tested by local parts store.
Sgt_Syke is offline   Reply With Quote
Old 01-14-2014, 03:21 PM   #3
Sgt_Syke's Avatar
Auto parts store should be able to check it. Why do you suspect computer is bad?
Old 01-14-2014, 03:22 PM   #4
Sgt_Syke's Avatar
Sorry, first reply wouldn't post, so I cancelled it, and tried again, that's why there are two of the same thing.
Old 01-14-2014, 04:19 PM   #5
Site Sponsor
Sponsor
AMWill's Avatar
The older OBDII PCM's are much more difficult to check, if faulty. Since a Ford Tech can't plug in their scan tools to flash the overall PCM. However, there is an input port for data to transfer in the OBDI PCM's, which a Ford Dealer may be able to connect to, but I can't say I've ever tried in on this style PCM.
Regardless, what makes you think the PCM is bad? PCM's VERY rarely go bad. Most of the time PCM's are diagnosed faulty, there's really a separate electrical issue causing the original problem(s).
Give me some more details about the issues you're experiencing and we may be able to figure out what's going on!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 01-14-2014, 08:54 PM   #6
I had a screw chip from american muscle but when it was in it made the car act like as if someone turned the key of and on real quick while I was driving and the idle jump up and stay up high. I've changed everything now I notice at idle the the alternator needle jump up and down slightly with the idle. I need serious help
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
Sct chip
Old 01-15-2014, 03:46 PM   #7
Site Sponsor
Sponsor
AMWill's Avatar
Sct chip
This could be as simple as a few bad grounds. Also, check the main power line coming off the alternator and make sure it's not corroded/rusted. It sounds like the who care isn't getting consistent power and is trying to survive on the fumes it's running on. I think you should try and through electric check before purchasing anything. Check all the grounds and main power wires. If they look okay, test the alternator and battery too!
Shane
Old 01-15-2014, 03:53 PM   #8
Right now I just found that the distributor is one tooth off
Old 01-16-2014, 01:13 AM   #9
TheRoadWarrior's Avatar
Follow OBD I KOEO and KOER, cylinder balance test etc. Computer will test itself as part of the diagnostics.
1995 GT. HCI 3500stall 4.10 gears.
1986 SVO project.
TheRoadWarrior is offline   Reply With Quote
Old 01-16-2014, 02:52 PM   #10
Site Sponsor
Sponsor
AMWill's Avatar
That's definitely not going to help your issue! Good find. However, as long as the engine is running- I don't see how this would drastically impact the voltage from the alternator enough to vary with engine surge. How well does the car idle actually? Is the RPM drastically varying?
Shane
Old 01-16-2014, 03:45 PM   #11
Well it has a e303 cam it idled good but I'm just try to make sure what it is before I send back my chip to AM. I'm stressed out.
Old 01-16-2014, 04:12 PM   #12
Site Sponsor
Sponsor
AMWill's Avatar
The E303 camshafts idle smooth enough that the RPM's should be jumping. How much are they ranging exactly?
Also, you're correct about fixing this before adjusting the tune. Otherwise the Bama Team will be chasing their tail for corrections if the car is not mechanically sound. Smart move!
Now what other details can you give me about the cars current condition? Tell me everything you've already checked.
Shane
Old 01-16-2014, 08:43 PM   #13
My car has edelbrock performer heads and intake 1.72 roller rockers BBK fuel regulator 70mm throttle body 76 mas cold induction msd 6al msd coil cap and rotor new plugs and wires 24lb injectors.
Old 01-16-2014, 08:47 PM   #14
Timing 10 degrees 355 gears bbk shorty headers aluminum drive shaft 200 amp alternator.
Old 01-17-2014, 08:08 AM   #15
92coupe's Avatar
Do you have factory gauges? How much does the voltage needle jump?
92coupe is offline   Reply With Quote
Old 01-17-2014, 08:09 AM   #16
Yes I do
Old 01-17-2014, 08:14 AM   #17
Needle moves 1/4 inch to the left and back to the middle of th 8 and 18
Old 01-17-2014, 12:59 PM   #18
Site Sponsor
Sponsor
AMWill's Avatar
How old is the MAF sensor? Have you tried cleaning it with MAF cleaner? If not, you might as well since this is cheap maintenance. If it helps, than great, if not than at least you have MAF cleaner for the future.
Looks like you have the right base timing too (10*). Did you say the lights were flickering or just the voltage is moving? Can you take a quick video of the cars symptoms and post it?
Shane
Old 01-17-2014, 06:21 PM   #19
92coupe's Avatar
Vacuum leak?
Old 01-20-2014, 05:40 PM   #20
It won't let me post video.
Old 01-28-2014, 08:47 PM   #21
So I pulled the computer and replaced it with another one just the same and didn't put the chip in the new computer and it runs fine. Good but now don't know if the chip killed computer or did it just go bad.
Computer Setups :D 1slosix The Bar 6 12-28-2012 03:19 AM
Proj Detroit-Like Computer Instrument Cluster kenny9091 2011-2014 V6 Mustang 1 09-26-2012 07:02 PM
computer reset 98mustang11 Pre-2005 V6 Mustang 9 02-19-2012 09:08 AM
Flashed Computer mcdonaldnick 1979-1995 Mustang GT 5 10-29-2011 12:14 AM
Building a computer tower... input needed jimmy_beaner The Bar 52 09-06-2011 09:48 PM
04:22 PM
