going from 3.27's to 3.73's will I notice a diffrence? - Page 2 - Mustang Evolution
Old 01-21-2014, 02:11 PM   #36
89GTstanger's Avatar
Manual valve body, reverse gear pattern, 2800+ stall... AwwwWWWW!!!!
That's cute... TKO 600, Ram high performance clutch, whatever stall I want...lol ... a real mans transmission... lol...jk man. All in good gun
You can't lose if you put God first!
1989 LX, 306 with TF top end kit, Anderson N-21 cam, TKO 600 trans with steel splatter shield,full Maximum Motorsports Mustang maximum Grip box, Detroit locker rear end with 31 spline Moser axles. Staggered wheels with Nitto 555 315/35/17 out back.
89GTstanger is offline   Reply With Quote
Old 01-21-2014, 02:14 PM   #37
mystang50's Avatar
I almost considered a manual valve body a while back
Old 01-21-2014, 02:17 PM   #38
Mosified's Avatar
I like the Manual/Auto valve body. Does anyone know if it can be done for sure to my 4r70w? I couldn't find any info....
Old 01-21-2014, 02:44 PM   #39
Don't get style points at the 1/4 for having 3 pedals
---------- Post added at 04:44 PM ---------- Previous post was at 04:43 PM ----------
I'm almost positive Art Carr is the guy who builds the auto/manual ones but honestly I'd go one or the other.
Old 01-21-2014, 02:45 PM   #40
I dont do drag strips. I'd rather auto cross if anything.
Old 01-21-2014, 03:27 PM   #41
94gtconvert's Avatar
The tko is a very strong transmission but cannot shift as fast or smooth as a regular t5. I heard if you try and rush the tko 600 you can shatter the blocker rings.
94gtconvert is offline   Reply With Quote
Old 01-21-2014, 03:38 PM   #42
I haven't had the car long but so far I haven't noticed any issues with it. I have read the same thing tho. I've had 3 t-5 transmissions and idont notice any difference. I'm going to replace the Hurst shifter with a MGW and that will smooth it up some more also. Or so it has in the past.
Old 01-21-2014, 03:42 PM   #43
Nothing a little short throw action can't fix lol
Old 01-21-2014, 03:53 PM   #44
Well like I said...I have no issues with mine. The short throw will help, obviously, with how far I have to move the handle to shift. As for smoother than a t-5, not that I can tell.
Old 01-21-2014, 03:56 PM   #45
I mean the speed from gear to gear, but yea the shifter won't fix notchyness. My brothers notorious mt-82 in his new 5.0 cleaned up real nice with the burton kit, it's smooth and direct.
Old 01-21-2014, 04:00 PM   #46
I've also heard the putting carbon fiber syncros will smooth it up a lot. I may actually do that in the future. All i need is a kit and directions and I'll do it muself.
Old 01-21-2014, 04:12 PM   #47
Synchro rings wont' do much for a TKO, its an inherent design flaw in the transmission itself. I had a TKO in my 95 and I wanted to set it on fire, I HATED that damn thing. If you don't notice the difference between it and a T-5 then something was wrong with your T-5. The T-5 should fall into gear with the lightest pressure at any RPM and the fresh/low-mileage ones I've had in the past confirm this.
I would never have a TKO again ever, if I had a 5.0 it would be an Astro A5 all the way. Light, strong, smoooooth T-5 action, .58 final drive ratio there honestly is no reason to use any other trans. Or you can also do a built 3650 behind a 5.0 with the bellhousing delete plate it bolts up to any TKO style bellhousing. With all the stuff out now I would dump a TKO in about 2 seconds and get something else but YMMV. If yours is smooth and powershifts well consider yourself really lucky and roll with it. Not everyone has the same definition of smooth though.
Old 01-21-2014, 04:16 PM   #48
I have heard understanding the concept of how a manual works is easier than an automatic, but manual transmissions are harder to rebuild. My automatic has a carbon fiber overdrive band.
Old 01-21-2014, 04:25 PM   #49
Overdrive should never never NEVER be used when the car is under power.
Old 01-21-2014, 04:26 PM   #50
I only use mine on the highway, what do you mean? Like Kent shut it on off off while your moveing?
Old 01-21-2014, 04:29 PM   #51
It means that if you are going to stomp on it from a roll on the highway you hit the "OD OFF" button first and then have fun. The computer SHOULD downshift on its own but if you did manage to put a lot of power through it while it was still in OD you can royally **** something up.
Old 01-21-2014, 04:33 PM   #52
Yes I know this. Whenever I'm doing 45ish and I'm about to turn off in to my town I give it some input so it's not a dry shift and turn overdrive off and it makes a wonderful downshift noise and my exhaust crackels. I only use overdrive if I'm going 45+
Old 01-21-2014, 04:38 PM   #53
I will definitely keep this on mind. This is my first TKO and I've only had it a few weeks. So far I'm really liking it a lot. I love how it shifts, I'm also liking the close gear ratio.
Rear Gears: 3.55s or 3.73s? TheJigShow 1996-2004 Mustang GT 5 09-28-2011 12:23 PM
08:47 PM
